Questions about Transistors with high beta (hfe) up to 3000 without Darl.-Topology
Old 11th December 2011, 10:05 AM   #21
davidsrsb is offline davidsrsb  Malaysia
Nice device at around 100mA. Only 60V (80V for A suffix) so good for +/- 25V rails. The ft curve is at 12V and is likely to drop a lot at lower voltage typical of cascode for higher rail voltages
Old 11th December 2011, 01:08 PM   #22
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by Sch3mat1c View Post
Oh, my mistake it's 2SD1273!
Short form spec from datasheetarchive:
Surprisingly Vce(sat) is tested at only 40 hFE, however it will gladly do the same with much less base current. It starts to look like a FET with Vgs(th) = Vbe, in that you hardly need any current to drive it -- enough that, whatever peak capacity a gate drive source would supply (even logic level), it's more than enough to turn this thing on.
Tim
thank you.
2SD1273/2SD1273A - hFE Rank classification:
Q: hFe = 500 to 1000
P: hFE = 800 to 1500
O: hFE = 1200 to 2500
The outline is TO220F.
http://www.datasheetcatalog.org/data...c/2SD1273A.pdf
http://www.datasheetcatalog.org/data...JD00065BED.pdf
Are there also an TO220 version sourced from the same process in a non isolated outline ??
Old 12th December 2011, 04:12 PM   #23
rayfutrell is offline rayfutrell  United States
In a 2007 article I can't find, Bob Pease pointed out that as transistor beta increases the transistor mu decreases. As the beta increases the Hre increases (becomes worse) and the early voltage decreases. Mu is the inverse of Hre and the theoretical maximum voltage gain is the early voltage divided by the thermal voltage. High beta isn't all good.
Old 12th December 2011, 06:17 PM   #24
mean you this author?
Bob Pease - Wikipedia, the free encyclopedia
http://www.eeweb.com/spotlight/interview-with-bob-pease
Old 13th December 2011, 04:03 PM   #25
Yes, that's him. I think his article was in EDN magazine in late 2006 or early 2007, but I can't find it. If I recall, he said that too much beta would adversly affect the transistor voltage amplification. I emailed him requesting an explanation because I had never heard that before. He explained that the higher the beta, the lower the mu. If you have ever seen a superbeta transistor on a curve tracer, the early voltage is very low.
Old 13th December 2011, 05:00 PM   #26
perhaps the article is mentioned in one of the TOC's about
2007 Print Archives | EDN
or
2006 Print Archives | EDN
Unfortunatly only from this year there are to find cover images of this magazine about
2011 Print Archives | EDN
here a photo galerie of the author from this article:
http://www.edn.com/blog/Anablog/4116...to_gallery.php
Old 13th December 2011, 06:33 PM   #27
I think the article may be in ED not EDN, but I can't find it.
Author : Bob Pease
Old 13th December 2011, 07:01 PM   #28
Found this, but I still can't find the article. It has to be there somewhere.
http://www.electronicdesign.com/arti...lbox18153.aspx
Last edited by rayfutrell; 13th December 2011 at 07:08 PM. Reason: link to article didn't work
Old 13th December 2011, 08:21 PM   #29
Finally found it. I looked all afternoon for this.
What's All This V<sub>BE</sub> Stuff, Anyhow? (Part 2)
Old 13th December 2011, 09:09 PM   #30
Thank you very much for your efforts to find this paper.
Part 1 you will find about:
What's All This VBE Stuff, Anyhow?
Best of Bob Pease - overview
The Best of Bob Pease
Book "Analog Circuits" read samples:
Analog circuits - Bonnie Baker - Google Bücher
File Type: pdf Bob Pease Whats All This VBE Stuff Anyhow Part1+2.pdf (54.7 KB, 46 views)
Questions about Transistors with high beta (hfe) up to 3000 without Darl.-TopologyHide this!Advertise here!
measuring hfe / beta gain Parts 10 12th October 2013 02:43 PM
Matching transistors - Measuring hfe TomWaits Solid State 118 3rd March 2007 07:22 PM
Need low power high beta transistors - please drop me a few part numbers... peufeu Solid State 37 3rd November 2006 01:22 AM
Confused over hfe variation in BC559 transistors Beggar Parts 5 29th September 2002 07:13 AM
Copyright ©1999-2017 diyAudio
