High Power Amplifier - Page 2 - diyAudio
Old 8th December 2011, 07:45 AM   #11
east electronics's Avatar
Originally Posted by moschfet View Post
If you don't see it, but Q14,20,21,22,23 are wrong wired.
The emitter must wired at positive voltage.
think it over .... i think you are wrong
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 8th December 2011, 07:47 AM   #12
try to work with a schematic that features some protection ...either LDR or Vi limiter ....this amount of power without any limits might become catastrophic for the amplifier
taj idea will work much better than yours
kind regards sakis
Old 8th December 2011, 10:08 AM   #13
are you saying that the pnp and npn is placed wrong and the npn shall be n the top with positive voltage and pnp in negative voltage ? i will try working on some protection, i am mounting an lm35 on the heatskrink that gives signal to an arduinoboard and if the temp goes to high it will clip the relay on the transformer and the speakerrelay also . i am thinking about using the arduino board and a current limiter : http://www.sparkfun.com/datasheets/S...oard%20v12.pdf
i then add a display to show the temp and the current. will that work or is it better with LDR or Vi limiter?
Old 8th December 2011, 10:33 AM   #14
will this work ?
Old 8th December 2011, 11:06 AM   #15
No.
You still have devices upside down.
You still have parallel devices with zero emitter resistors.
You still have mixed AC and DC coupling.
You still have unusual input filter values.
Weird decoupling philosophy.
mje340 as a VAS device??????
R16 & R18 killing the performance of the VAS stage.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th December 2011, 11:18 AM   #16
i am simulating in multisim, can some of you open it and try making what you are writting, i am not understanding all you say ?
Old 8th December 2011, 01:27 PM   #17
moschfet's Avatar
I doubt that the new circuit can be simulated correctly. It seems as if you have no basis. Extensive knowledge in electrical engineering can not convey in a forum.
Why not first you build a working circuit?
Copier is no disgrace.
Regards http://xipix.de/
Old 8th December 2011, 02:07 PM   #18
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by anders3408 View Post
have an 1.3kW trafo that gives +- 58volt
will the amp i had designed be stable at 2 ohm or as low as 1 ohm ?
planning to build 2 of the amps and thinking on bridging the 2 pcb and drives it in 2 ohm bridge ?
not impossible, but even the most experienced builders would have a hard time to make this happen
you will have to lower your expectations, a lot
apart from it would cost a fortune in burned parts, it could actually burst into flames, literally
Old 8th December 2011, 02:40 PM   #19
expert in tautology
bear's Avatar
Bridging is likely to exceed the SOA of the devices very quickly...
Otoh, a beefed up driver and a ton of output devices is an option...
But first build a small version like the driver and a simple output with just two devices to check that it is stable and works... not into a low Z load. To me the output stage is just odd... but I am not that good at this stuff.
Listen to Andrew about the FB.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 8th December 2011, 03:11 PM   #20
You have complimentry output devices. Then Q13 is used as a level shifter as would
be used in a quasi complimentry output stage.
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview tiefbassuebertr Solid State 54 12th March 2017 01:01 AM
Power amplifier at high frequency Luckyboydtt Chip Amps 18 31st October 2008 07:20 PM
HIGH Power Sub amplifier? Killjoy99 Solid State 31 18th September 2006 01:54 AM
request high power amplifier mohandes_milad Class D 4 23rd August 2005 01:01 PM
Copyright ©1999-2017 diyAudio
