Amplifier mains hum help
Old 7th December 2011, 05:17 AM   #11
killersoundz is offline killersoundz  United States
Originally Posted by tauro0221 View Post
If you have a voltmeter read the rail voltage with the meter voltage selector in AC. The voltage should read close to zero. If it's read close to zero the power supply is OKAY.
Sorry, where do I take this reading at?
Old 7th December 2011, 07:06 AM   #12
Enzo is offline Enzo  United States
With respect to chassis ground, there will be two main power rails in the power amp. The easy place to check that would be the center leg of the power ttransistors. The two on the left is one supply and the two on the right the other.
Also look at each power transistor, and see a litttle bit of metal exposed in the mounting tab area. That is electrically the same as the center leg. Just make sure your meter probe does not short that to something nearby in the process.
Old 7th December 2011, 04:43 PM   #13
R.I.P.
Originally Posted by killersoundz View Post
Do you mean the main input jack on the front panel of the amp or the input plug on the power amp board?
If there is more than one input plug, then try every option !!!!
regards Andrew T.
Old 7th December 2011, 05:27 PM   #14
tauro0221 is offline tauro0221  United States
You can check the positive voltage at Q16 and the negative voltage at Q17.
Amplifier mains hum helpHide this!Advertise here!
Mains Hum - Are cheap caps worth it? HiFiWill Solid State 4 9th September 2011 06:42 AM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
mains hum prob polyal Analog Line Level 3 26th March 2008 02:41 PM
diagnosing mains hum baldy Solid State 3 17th October 2007 01:16 PM
Zapulse mains hum since going dual mono ewildgoose Class D 11 26th December 2005 08:52 AM
