#21 |
You definitely need a scope to see crossover distortion, especially low level distortion.
You can hear bad or medium crossover distorion as a harshness in the sound at low level. Push pull can give excellent results. I have designed a few mosfet amps and all of them had no crossover distortion when the bias was tweaked correctly. In fact I was gobsmacked at sometimes how little bias was needed to get rid of crossover distortion. I have used irfp240/9240 with good results.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#22 | ||
All the trouble I've ever been in started out as fun......
#23 | |
I have got as low as 10mA bias current and no crossover distortion. It would be interesting to get a distortion analyser on it too see what is really being put out tho.
#24 | |
Just to be clear, I'm not advocating low bias currents for output FETs, that's probably where some misunderstanding is coming from
Negative Feedback: The Need for Speed Last edited by MagicBox; 8th December 2011 at 07:03 AM. |
#25 |
May he (nigel) mean if it underbiased. Hi,CBS. Do you have another EC or still using your old one?
#26 | |
Cheers, Bob |
#27 |
Hi Bob,
Everyone said that they are different. I also have found that they switched easily than laterals, more in higher Vds. Not happened in SPICE level 1 simulation but happened in level 3. higher Vds effect only happened in real and not happened in level3 simulation. Dont no why. What is EKV SPICE model, I am currently using SPICE level3 MOSFETS model. |
#28 |
Nelson in his A40 article touches on another effect that hapens in the crossover
region. The output impedience where it is verry high in the crossover region of a class B amp and is lower and more stable in a class A output stage. Here Is a crude picture from the pdf of the article. I didn't know how to export a picture so I just took a picture. I wonder if the difference in output impedience effects speaker damping. Taking to an extreme supose an amp had an output impedience of .1 ohm at 10 mw but had an output impedience of 10 ohms at 10 W couldn't that realy mess up the frequency responce. |
#29 | |
I discuss the EKV model in my book (Designing Audio Power Amplifiers) and show how to create one's own models with one's own laboratory measurements. Sometime soon I hope to be able to post EKV models for laterals and verticals on my website at CordellAudio.com - Home. Stay tuned. Cheers, Bob |
#30 | |
You will find extensive discussions on crossover distortion in my book, both for MOSFETs and Bipolars when used in push-pull output stages. An under-biased class AB BJT output stage has its output impedance rise as the output current goes through the crossover region, and its incremental gain will decrease, causing distortion. An over-biased class AB BJT output stage will exhibit a lower output impedance in the crossover region, leading to a phenomenon sometimes called gm doubling. MOSFET class AB output stages suffer from transconductance droop, originally described in my AES paper on a MOSFET power amplifier with error correction about 30 years ago. With transconductance droop, the output impedance increases as the output current goes through the crossover region, and the output stage incremental gain goes down, causing distortion. Cheers, Bob |
| Push Pull vs Normal Distortion Compared | weltersys | Subwoofers | 25 | 2nd September 2012 09:37 PM |
| "Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? | tiefbassuebertr | Solid State | 70 | 15th August 2012 08:08 PM |
| Push-Pull vs Push-Pull-Parallel | rsumperl | Tubes / Valves | 8 | 10th July 2012 05:34 PM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
