Old 5th December 2011, 10:04 AM   #1
robmil is offline robmil  United Kingdom
Default Mr Gromer LNA-1 opamp - 2SC2239BL equivalent
Hi Chaps
My stumbling block is low noise transistors. I
Old 5th December 2011, 10:11 AM   #2
great...pressed send while the diyaudio site was doing some work.
basically, I'd like to drop in the Sam Gromer SG LNA-1 into my dynavector P75 stage to see what if any improvements I might get. I'm using a Denon 304 (0.18mV) and with the P75 using the LT1115 the noise levels are OK.
Problem is that the SG opamp uses the 2SC3329BL which is now discontinued.
What to do? Is there any other ultra low noise design out there that DOESN'T use discontinued parts. The JE990 uses the LM394. I need something that is OK with low output moving coil cartridges, down to 0.18mV.
thanks guys
Old 5th December 2011, 10:30 AM   #3
Terry Demol's Avatar
thanks guys
Do some searching around here and through data sheets
2SC2545 / 46 / 47
2SA1083 / 84 / 85
Haven't measured them but data sheet shows similar specs.
cheers
T
Old 12th December 2011, 08:52 AM   #4
Originally Posted by Terry Demol View Post
2SC2545 / 46 / 47
2SA1083 / 84 / 85
The datasheet on Renesas' website is marked "Not Recommended for New Design", so make your once-for-all-time purchases soon . . .
Dale
Old 13th December 2011, 07:10 AM   #5
I've given you a perfect replacement here: Samuel Gromer low noise opamp
Also a lot of other low noise parts are given in this thread.
Samuel
Old 14th December 2011, 03:51 PM   #6
homemodder's Avatar
Try 2sa1207 or 2sa1208, hfe might be slightly lower but noise figures are very close to the hitachi parts, very low Rbb.
New DIY Project for measuring noise : 10Hz..100kHz LNA // 1MHz RMS-DC converter Frex Equipment & Tools 54 13th April 2012 04:13 AM
Samuel Gromer low noise opamp robmil Solid State 12 28th April 2011 12:11 PM
Simple 60dB discrete low noise amplifier (lna) ikoflexer Solid State 440 19th November 2010 04:18 PM
Mr Bose, meet Mr Radio Shack larry wiley Multi-Way 18 2nd February 2005 06:49 AM
NI unity gain opamp equivalent but with discretes needed jondoe Solid State 5 10th December 2004 06:45 PM
Page generated in 0.08204 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
