Old 3rd December 2011, 03:36 PM   #1
tiefbassuebertr's Avatar
Default RCA Power Transistors BD750, BD751, BD550, BD550A, BD550B Data Sheet wanted
I recall, that I have had RCA Datasheets/application notes from the German Distributor Alfred Neye ENAtechnik in Quickborn. Unfortunately I don't find this sheets sine a long time.
Here the exactly naming of this papers:
1) "Power Transistors BD750, BD751 Series"
RCA File Number 1251
Titel: "Silicon Transistors for 80- and 100-W Full-Complementary-Symmetry Audio Amplifiers" (Printed in USA/11-80)
2) "Power Transistors BD550, BD550A, BD550B",
RCA File Number 1109
Titel: "Silicon Transistors for 70-, 120-, 200- and 300-W Quasi-Complementary-Symmetry Audio Amplifiers" (8.78/AT3679-10.78)
I don't know, whether the term 10.78 and 11-80 means the date of release, but it is not excluded.
Who can post this papers ??
Thank you for your efforts in advance.
In the attached files you will find a schematic, where this types are in use.
Old 3rd December 2011, 09:40 PM   #2
indianajo's Avatar
Don't have any RCA app notes but since I dug through the attic for you, you can read this & throw it away. 1986 RCA SK book shows BD550/a/b as SK9031. BD750/a/b is SK9033. These are NPN TO3 BJT, PNP complements 1 digit higher. SK9033 suffixed as 60, SK9034 suffixed as 61, and I own some NTE60's installed an 80V rail quasi comp amp. SK9031 Pt 150w, Ic 20a (9032 is 16a) Bvceo 160, typ hfe 20, typ Vcesat 2v@5a, Ft 2 mhz. SK9033 250 watt, 20A, Vceo 140v, typ hfe 75, Vcesat 2v@5a Ft 2mhz.
Parts seem to be a bit tougher than a 2n3055.
For those that don't know NTE started as a copy of the RCA SK and similar GE replacement part lines, using primarily imported parts. NTE is the only survivor of this marketing program. RCA & GE gave away the catalogs, NTE made the sale without having to hire any expensive salemen. The part numbers were the same except for the prefix.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 4th December 2011, 10:11 AM   #3
Thank you for this advices.
in the databook about
Sitio Hasa - Circuito, Esquema, Reparacion, Integrado, Electronica, Hardware, Audio, Manual, Fallas, TV Color, Componente, Libro, Auto
and the URLs
Pagina principal Eshop
there are mentioned this SK-Series from RCA
and also by this URL as replacement for Altec's factory type No 121540:
Looking for RCA 121540 Transistor replacement
about
RHS
and
Card Catalog by title 8 29 101
I have found a PDF file ( I attached the excerpts from RCA), there are mentioned follow RCA papers:
2638 RCA RCA Silicon Power Circuits Manual, SP-50
2262 RCA RCA Silicon Power Circuits Manual, SP-51
878 RCA RCA SK Series Solid State Replacement Guide (SKG202-D)
147 RCA RCA SK Series Top of the Line Solid State Rep. Guide, 1978
3068 RCA RCA Solid-State Power Circuits (SP-52)
about
SK9034 PNP Power Transistor
there are still an offer for the type SK9034
U3090MG (Display Driver Vishay-TFK) for FV112 Futuba Data Sheet wanted tiefbassuebertr Solid State 8 31st January 2012 08:21 AM
TC94A27BUG Digital Volume Control Data sheet wanted Zero Cool Parts 0 22nd February 2010 10:57 PM
looking for old data sheet unclejed613 Parts 3 13th May 2007 06:35 PM
data sheet KCC Parts 5 6th January 2004 09:03 PM
KT81 data sheet? EC8010 Tubes / Valves 11 21st April 2003 03:25 PM
Page generated in 0.07916 seconds (77.66% PHP - 22.34% MySQL) with 11 queries
