Old 2nd December 2011, 05:49 PM   #1
Default cheap big binding posts for metal chassis
I have another thread on this in the parts forum, but people building amps are really the ones I want to ask.
need binding posts for #4 wire, mount on steel plate
What do you use for an affordable (cheap!) binding post that takes large #4 wire and mounts insulated from a metal chassis? I can't find 'em... I'm using them on steel plates on a bunch of bi-wired speakers, so I don't want to spend thousands of dollars on Mundorf parts.
If the #4 guage requirement is the problem I might consider a little smaller.
What I'm finding cost more than the drivers did.
Old 2nd December 2011, 06:50 PM   #2
I can't answer your question, but I have a wild idea. Why use steel plates to mount them? You do say that it is inside a speaker cabinet. If you mount them on a piece of wood, you can use any old cheap nuts and bolts as mounting posts. Just a thought.
Old 2nd December 2011, 07:09 PM   #3
McMaster-Carr
http://www.mcmaster.com/#catalog/117/3224/=f6w34z
Has hex bar stock. You can drill a few holes and make your own speaker terminals!
Old 2nd December 2011, 09:07 PM   #4
Yes, on previous systems I just put huge brass bolts thru the cabinet with brass double locknuts and a brass wingnut. From McMaster-Carr.
I already have the cabinets cut for the plates, which are mostly to mount the Neutrik connectors.
When I use them at home I like to use my heavy flat oxygen-free cables. When I'm out I plan to use round cord with a Neutrik, but thought the binding posts might still be handy to wire the driver banks in parallel so the 4-conector Neutrik would work with a 2-conductor neutrik cable too.
For now I might just throw them together and use the Neutriks.
Old 3rd December 2011, 09:40 AM   #5
What size is ~4 wire?
4mm diameter or 5mm diameter or even inches would help.
I know that cheap 5way binding posts are available in 4mm size and there are a few 5mm versions.
regards Andrew T.
Old 5th December 2011, 04:21 PM   #6
AndrewT:
Are available where?
Old 5th December 2011, 04:25 PM   #7
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Why cheap , what about good ..? I'm using this to make mine ..
Order Copper 101 Round in Small Quantities at OnlineMetals.com
Old 5th December 2011, 04:34 PM   #8
By cheap I mean "inexpensive" but very functional and durable. I'm bulding mulitple subs, and it's a bit frustrating that the cabinet hardware doubles the cost. If I need 16 binding posts, I can't afford $100 Mundorf terminal posts; IMHO they should not cost 3 times as much as the drivers.
Old 5th December 2011, 04:36 PM   #9
I have no idea what the average dimensions of #4 wire are, that's just what some "Unavailable/backordered" ones claimed, and I think my home wire is probably more like #10 anyway; I'd just like BIG strong terminals.
Old 5th December 2011, 06:23 PM   #10
Found some interesting ones:
Input Cups G25-CUP: Madisound Speaker Store
gainclone / chassis / binding posts merlin2069er Swap Meet 4 24th November 2010 08:37 PM
Alternatives to soldering big speaker binding posts iwf Construction Tips 8 31st October 2010 01:44 AM
Binding Posts ANDYLASER Swap Meet 5 25th June 2010 11:14 PM
Binding Posts ANDYLASER Swap Meet 7 23rd November 2006 11:33 AM
WTB: 10,000UF Caps, 1000-1500VA 40-0-40 transformer, Amp Chassis, binding posts, etc. Spiritzly Swap Meet 2 25th August 2006 04:07 PM
Page generated in 0.10122 seconds (76.10% PHP - 23.90% MySQL) with 11 queries
