Old 3rd December 2011, 12:41 AM   #11
Default The Cloud
The planet goes green
Old 3rd December 2011, 02:24 AM   #12
Default still exploring
With a high pass filter the curves are a bit cleaner. Feel free to chip in.
Old 3rd December 2011, 03:15 AM   #13
Default are these curves satisfactory
Here are the curves from the latest mod.
Old 5th December 2011, 06:46 PM   #14
Hi all,
These curves are not bad , can be compared to Self's, small signal fig 11.8, 11.7 and 11.9, it falls in some where there. Also the B5 bass curve can serve as a reference http://www.firstwatt.com/pdf/prod_b5_man.pdf, although the B5 does more than that. Also Linkwitz has some interesting curves here Linkwitz Lab - Loudspeaker Design.
But please this is still open to discussion.
kind regards,
Harrison.
Old 9th December 2011, 02:44 AM   #15
Default latest mod
Comments welcome, also there is an interesting article in the MIX magazine Dec 2011 page 60. Seems this kinda pre amp is hot at the moment.
Old 9th December 2011, 07:19 AM   #16
The Bass is marginal while the treble borders on useless. You will not like how it works.
Old 9th December 2011, 07:33 AM   #17
Old 9th December 2011, 08:26 AM   #18
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
It was hot 35 years ago too - I remember building something similar . . . with LF356 op-amps (very late 70's in my youth) . . .
Your tone control curves are looking quite good, and the return to zero is very important if you want to avoid amplifying supersonic noise etc.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 9th December 2011, 12:17 PM   #19
Look at Hi-Fi Preamplifier by ESP. This design gives a more sensible and subtle tone adjustment range of +/-10dB whereas the more "traditional" designs use +/-20dB.
I built this circuit using LM4562 op amps, have used it for around 18 months and find the quality and adjustment range excellent. The gentle tonal corrections it offers seem perfect when compensating for the room acoustics.
currentflow
Old 9th December 2011, 02:35 PM   #20
Bonsai's Avatar
I agree. For tone controls, 10 db at the frequency extremes is about right.
bonsai
A certain HAL Amplifier OnAudio Solid State 0 23rd November 2011 03:41 PM
Preamplifiers v power amplifiers otto88 Tubes / Valves 15 15th September 2010 04:54 AM
Hafler Preamplifiers - DH101 vs. 915 bcrescen Solid State 6 14th July 2008 09:30 PM
HAL-O Damping Instruments Tazzy Tubes / Valves 7 14th October 2004 02:24 AM
Tube Preamplifiers Peaceseeker Tubes / Valves 16 22nd July 2002 09:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
