Old 1st December 2011, 02:10 AM   #1
seanvn is offline seanvn  Viet Nam
Default High input impedance BJT preamplifer
Just as a curiosity I have posted a high input impedance BJT preamplifer circuit here: Dual Bootstrap Preamplifier
If only people would go back to using crystal microphones it would be useful! Actually I do have an application for it anyway. It uses 2 transistors and has 3 feedback loops. I am certainly interested in any improvements but I don't want to use JFets or whatever.
Old 1st December 2011, 10:33 AM   #2
CBS240 is offline CBS240  United States
CBS240's Avatar
Why?
I was going to suggest using matched EPAD mosfets from ALD (Advanced Linear Design). 1pf of CISS.
Look for a high Hfe BJT, at least this way you can 'see' a fairly high Z from looking into the base. I use a high imput Z in my amp, ~150K, but it uses a specific J-fet as the input device...guess that idear is out.
All the trouble I've ever been in started out as fun......
Old 1st December 2011, 10:44 AM   #3
Does cascoding of the input BJT reduce the input capacitance? Or does it reduce the effect of varying input capacitance?
I'm wondering what effect this could have on HF input impedance.
regards Andrew T.
Old 1st December 2011, 12:00 PM   #4
RJM1 is offline RJM1  United States
High input impedance?
About 10K.
Although I didn't have the models for those transistors.
Old 1st December 2011, 12:41 PM   #5
CBS240's Avatar
Reducing the effect of varying junction capacitances for sure but also preventing it from operating close to Vce saturation. With 10V or more Vce, Ccb is significantly less than maximum. However, it seems to me, BJTs are less suitable for high input Z inputs. With 100nf input cap, if this is for full range audio low frequency Z is going to be very high, or else shifted in phase. If it is for a peizo mic or something a FET is most likely needed...a very small one.
Use the FET to drive the BJT.
Old 1st December 2011, 01:04 PM   #6
Oops, missed a connection, more like this.
question on very high input impedance for B1 wintermute Pass Labs 8 3rd April 2010 01:20 PM
High input impedance X circuit zelter Pass Labs 4 31st March 2009 10:06 PM
How high is the input impedance of 'a' jfet transistor? Hans L Parts 2 14th September 2006 02:49 PM
IGC with High input impedance! GregGC Chip Amps 0 30th April 2004 05:03 PM
P3A question: high input impedance sobazz Solid State 1 14th July 2003 05:45 AM
Page generated in 0.08426 seconds (71.55% PHP - 28.45% MySQL) with 11 queries
