Rod Elliot P3A Layout - Critics - Page 3 - diyAudio
Old 30th November 2011, 06:19 PM   #21
firechief's Avatar
Have you pruchased the parts yet? If you have them in front of you while you are doing the layout you can measure and play with them. This helps things go faster, reduces mistakes. How about ground plane? I would use a coper fill on top and make the bottom solid copper with the two sides connected.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 1st December 2011, 04:37 AM   #22
No firechief...I haven't bought the components yet..I'll be buying them soon.
Old 1st December 2011, 05:52 AM   #23
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hi, maybe I missed something, but how do you intend to mount outputs onto heatsink ?
Old 1st December 2011, 07:53 AM   #24
I intend to mount them on right-angled aluminium brackets.
Old 1st December 2011, 08:55 AM   #25
Francec is offline Francec  Australia
Banned
Why don't you just replicate Rod's layout? Obviously it works or he wouldn't have sold so many PCBs.
I've bought quite a few of his other boards and they always work. I'm listening to Rory Gallagher through several at the moment.
Old 1st December 2011, 01:32 PM   #26
That's a good idea...BUT!
I'm 15 yrs old and i don't get enough money that i can afford to buy Rod's PCBs!
Old 1st December 2011, 07:42 PM   #27
Nico Ras's Avatar
Your layout is not bad at all, components are to widely spaced, squeeze the whole amp, it will aid in shortening signal paths lengths. Your board can easily be shrunk by 50% and could look and work quite smartly.
U-Shaped heat sinks will not be good enough for your application, need something a little more substantial. Try changing R13/14 orientation because their far ends will short against the heat sink if it were mounted vertically. Also provide some securing mechanism for the heat sink, you cannot hang them off the transistors, you need some form of support.
Kindest regards
Nico
Old 1st December 2011, 10:03 PM   #28
Banned
Default P03A Image
Here is an image of the P03A PCB from Rod's web site. The image is open to the public so I am not infringing Rod's copyright or IP. Normally, I would, and do, suggest buying Rod's boards, as I do, but a poor 15 year old needs a little bit of help.
You can use this image to use a guide for parts placement then link up the pins.
Old 1st December 2011, 11:46 PM   #29
You can be sure paranoid has been reading Rod's ESP site, and several times over! Elliott Sound Products - The Audio Pages (Main Index)
Ian
Old 2nd December 2011, 12:46 AM   #30
Banned
Ian, the reason I posted the image was because I thought if the OP had seen the PCB, he/she would have made an effort to copy, to a reasonable degree, placement of parts and work from there. Seems sensible to me; why re-invent the wheel?
Frank
PS Coffs Harbour is a lovely part of the world.
Rod Elliot P3A amp noises tktran Solid State 75 23rd July 2016 03:35 PM
Rod Elliot P.68 Phase? samutacaratti Solid State 26 20th August 2014 04:39 PM
Rod Elliot P37? roger-k Solid State 21 7th October 2006 08:37 PM
Rod Elliot P3a boards stuffed FS! Mattyo5 Swap Meet 8 3rd October 2006 02:45 PM
Rod Elliot 100W PCB Layout bugbite2k Solid State 5 30th January 2002 06:32 PM
Copyright 1999-2017 diyAudio
