Rod Elliot P3A Layout - Critics
Old 2nd July 2013, 10:39 AM   #251
JLesterP is offline JLesterP  Philippines
Default please criticize
My old layout (in the pic) showed no signs of oscillations under scope.
Is my new layout good? Or decoupling is too far?
Should I change my old layout into this?
amplifier PCBs and modules
Old 2nd July 2013, 11:58 AM   #252
Bone is offline Bone  United Kingdom
If it aint broke dont fix it!
Old 2nd July 2013, 12:56 PM   #253
I'm not fixing it, im improving it
Old 2nd July 2013, 08:07 PM   #254
Ian Finch is offline Ian Finch  Australia
Originally Posted by jlester87 View Post
..... im improving it
OK, then improve the thermal coupling between drivers and bias transistor so it doesn't take ages to stabilize and responds usefully to changes in dissipation.
According to the pics, you don't have a driver heatsink anyway, so what bias current are using now? You don't need to move much to allow better coupling with just a single heatsink for all 3 transistors, assuming you don't already have this arrangement but just haven't shown it here.
Ian
Old 3rd July 2013, 01:37 AM   #255
Hi, the drivers will be connected on a single heatsink. Bias transistor and Q5 are thermally coupled (glued by thermal epoxy), thus changes in Driver transistor Q5 will be quickly monitored by Q9.
5W output collector resistors are on the underside of the PCB.
Old 3rd July 2013, 02:47 AM   #256
Bigun is offline Bigun  Canada
Bigun's Avatar
Nice layout - I also used this approach for my TGM1, TGM2 and TGM3 - having power rails on one side and sensitive parts on other side.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 4th July 2013, 10:30 AM   #257
Thanks Bigun
What I liked with P3A(sziklai) is that only the O/P transistors are mounted on the main heatsink. This simplifies the work on the amp case. Also it has low parts count, so it is as easy to build as chip amps.
Old 4th July 2013, 10:49 AM   #258
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
that is why this amp is highly recommended for newbies.....as well as oldtimers....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th July 2013, 12:07 PM   #259
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Hi Tony, where is the oldtimers
I must give it a try...
Originally Posted by AndrewT View Post
The Power Ground does not need to be connected to the Signal Ground by using PCB traces.
The Power Ground and the Signal Ground need to be referenced to the same voltage. This can be on board, or it can be off board.
If you are building more than one channel into your amplifier, then I assert that the Main Audio Ground (where Signal ground and Power Ground meet) must be off board.
Originally Posted by gmphadte View Post
John Bali
The big filter capacitors have to be located close to the power transistors in order to reduce the inductance added by the long track.
Gajanan Phadte
So many critics to my own layout, thanks guys...
time to improving it
Thank you, I wish you happy
peace & G B U
Old 4th July 2013, 12:26 PM   #260
TonyTecson's Avatar
so many words....what does it amount to?
why can't AndrewT just show us in pictures what he's got so we can appreciate what he says....
Rod Elliot P3A Layout - CriticsHide this!Advertise here!
Rod Elliot P3A amp noises tktran Solid State 75 23rd July 2016 03:35 PM
Rod Elliot P.68 Phase? samutacaratti Solid State 26 20th August 2014 04:39 PM
Rod Elliot P37? roger-k Solid State 21 7th October 2006 08:37 PM
Rod Elliot P3a boards stuffed FS! Mattyo5 Swap Meet 8 3rd October 2006 02:45 PM
Rod Elliot 100W PCB Layout bugbite2k Solid State 5 30th January 2002 06:32 PM
