Rod Elliot P3A Layout - Critics
Old 30th November 2011, 12:53 PM   #11
ingenieus is offline ingenieus  South Africa
Placing Q9 on a heatsink by itself is a recipe for disaster. It provides thermal compensation, therefore it must be on the same heatsink as the drivers (Q7 and Q8). The closer it is to them, the better it will work. This means that your existing layout will have to change drastically, but that is just the way these things work.
Old 30th November 2011, 01:01 PM   #12
currentflow is online now currentflow  United Kingdom
Originally Posted by paranoid06 View Post
Thank you for your suggestions everybody, I've tried to edit the layout according to Alfonz's suggestions. Hope its better this time!
@sakis - what happens if the layout isn't up to the mark? Will it cause oscillations in the amp??
@kalmara - thank you for letting me know that! That was just something that cannot be avoided! And was out of carelessness.
@ingenius - Is it really necessary to keep them in a line? I was thinking of using U shaped heatsinks used for TO-220s
I've attached the edited layout.
Thanks and Regards
Hi paranoid06,
Re your layout - if Q7 and Q8 are vertically mounted on the PCB, you will need to move R13 & R14 away from the top board edge to allow for the heatsink. If you only intend Q7 & Q8 to mount flat on a right-angled bracket, this may not be a problem.
currentflow
Old 30th November 2011, 01:20 PM   #13
mdhull is offline mdhull  South Africa
It's a CFP output stage so thermal linking of the Vbe mult bias transistor is not mandatory
Old 30th November 2011, 03:13 PM   #14
paranoid06 is offline paranoid06  India
@ingenieus - I guess ur mistaken, Q9 is BC546!
@currentflow - I will be flat mounting them on a right angled aluminium bracket. So no worries! Anyways thanks!
Old 30th November 2011, 03:28 PM   #15
Another Edit!
Q4 and Q5 kept collinear.
Old 30th November 2011, 04:08 PM   #16
That applies for the pre-drivers but I'm not so sure about the Vbe multiplier. Douglas Self discusses the difference between thermal compensation for CFP and EF stages at some length in his book. He concludes that CFP has larger bias errors than EF and then describes ways to mount TO225 devices on TO3 or TO3P drivers.
Old 30th November 2011, 04:20 PM   #17
east electronics is offline east electronics  Greece
east electronics's Avatar
do the reading of the forum regarding this issue
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 30th November 2011, 04:27 PM   #18
It still has to go on to the heatsink. There are ways to do that. You could glue it on. You could also wrap it in a piece of copper tubing or copper sheet and bolt it down. I'm not sure about what works best. Somebody else might care to comment on this.
Old 30th November 2011, 04:32 PM   #19
discrete is offline discrete  Canada
For CFP there is local feedback in the output stage and the Vbe multiplier should be in thermal contact with one or both of the drivers, not OPs, if any.
PS: ESP makes a living from his website, selling PCBs for his projects among other things.
Support him and get the 'reference' boards at the same time!
Old 30th November 2011, 04:34 PM   #20
Yes. I am!
Rod Elliot P3A Layout - CriticsHide this!Advertise here!
Rod Elliot P3A amp noises tktran Solid State 75 23rd July 2016 02:35 PM
Rod Elliot P.68 Phase? samutacaratti Solid State 26 20th August 2014 03:39 PM
Rod Elliot P37? roger-k Solid State 21 7th October 2006 07:37 PM
Rod Elliot P3a boards stuffed FS! Mattyo5 Swap Meet 8 3rd October 2006 01:45 PM
Rod Elliot 100W PCB Layout bugbite2k Solid State 5 30th January 2002 05:32 PM
