Rod Elliot P3A Layout - Critics
Old 30th April 2012, 11:51 AM   #111
east electronics is offline east electronics  Greece
east electronics's Avatar
there is not much to say .... there is a million comments regarding pcb designs only you have to read them .
----Attaching the vas to one of the drivers will not provide thermal compensation... attaching the VBE multiplier to one of the drivers may provide some thermal compensation
( to my taste common heatsink both of the drivers and attach VBE on it for the best results )
---Bypass and decoupling will only work for the best if close to the outputs
---especially the one bypass located next to the vas miller cap is a tricky thing to do i t might cause some complication
---It is also wrong to have the LTP in Houston while the current source for it is in NY .... these three will need to be as close is possible
---The zobel and the ground return is or could be dirty so having it going all around the amplifier is not the best thing to do ... obviously one may benefit by re-placing the zobel in the output on the binding post rather than on the pcb...
now ... in real life the pcb you produced ( in a harry ) will work and play music class AB amplifiers are so forgiving ! Point is that if you aim for high quality and low distortion you will never make it with this pcb ....
Does it sound like someone is trying to milk the mosquito ? may be ... but design a pcb under those rules and the particular amp will meet the above specs
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 30th April 2012, 12:02 PM   #112
JLesterP is offline JLesterP  Philippines
I only attached the two temporarily so that when I solder it, it will be aligned, my goal is to common sink all of them...
Thanks, I'll revise/make another layout based on your suggestions here and on your p3a comparison thread
Old 30th April 2012, 12:11 PM   #113
Ian Finch is offline Ian Finch  Australia
I think he did a good job here - Sakis. You can send me a couple of those PCBs any time.....Just guess at the tracks, guys
Ian
Old 30th April 2012, 12:26 PM   #114
ian .....we ve been through this before .... The work i make for the P3a is based on rods schematic ( minus plus a few things ) but the boards i make i s only for personal use and i am not willing to give to any
Giving or selling boards ( even posting layouts of ) will be against Rod's interest and we all agree to respect a person that given so much in the diy community for free..
At least this is the way i see it
Kind regrads
sakis
Old 30th April 2012, 12:48 PM   #115
Tekko is offline Tekko
Banned
But in all honesty, is rod's own layout actually any better than the one posted in this thread ?
He does claim theres no possible way to come anywhere near the performance his boards offers, which is quite frankly pure bs and merely a claim to boost sales of his own boards.
My first ever discrete amp was the P3A and i built it on a piece of plywood with nails hammered into it at the joints on the schematic, worked just fine.
Old 30th April 2012, 01:11 PM   #116
Hi sakis I have a noob question,
How close are they should be? Is it relative to the size of the board (lesser interaction to other components) or absolute as in per inch? Because this board is only 3 x 2.5" and if measured in the length of the track I think they are pretty close...
Old 30th April 2012, 01:29 PM   #117
close doesnt have much to do by "the inch " close has some to do with what is in between
Old 30th April 2012, 01:46 PM   #118
Put it this way, Tekko - Rod sees a lot of copies of his boards because people think an auto- router in their PC software can do just as good and looks pretty, nice and close together etc. I've made PCBs by hand, artwork and cheap or free software for a lot of years but I can assure you that in hi-end audio and RF work, nothing is as good as someone who knows best spacings and position of parts, track alignments, thermal gradients, EMR patterns and who is designing for A1 performance with the skill and experience for it.
Typically, you can halve THD by smart trackwork in the output transistor traces and feedback routing. You can reduce noise by parts selection and location. Yes, you can learn that there are do's and dont's rules to follow like star grounding paths but do we know how much is necessary for optimum performance of the design? After 10-20 iterations and feedback, you might be getting somewhere. Rod has that experience with his very old designs but I don't think many people see it. It can make that difference between 500 Euro and 5,000 Euro amplifiers and of course, the odds you will ever get paid for any design. There are guys here who are breathtakingly good at commercial work but you see something else when you look inside the best fancy brands.
Sakis - I am just kidding you, see... It is actually a compliment to invite someone, just kidding, to give you what you like, no? Of course they just grin and say something nasty but that's life, we are old enough to understand we can't have everything. I wouldn't seriously ask anyone on Forum for any IP unless they offer it as a group buy etc. Sorry if I offended you, my friend.
Ian
Old 30th April 2012, 01:51 PM   #119
Anyway I already assembled the amp and the only modification that I can make is to have the zobel in the output terminal, too bad I don't have the test equipments to measure and compare it to published specs.
When I powered it up, the amp runs relatively cool with 75mA bias, I will connect it to my main speakers once I integrate a speaker protection circuit...
Old 30th April 2012, 01:59 PM   #120
no worries Ian .... the code of communication between us is very well established so we both speak the same language .....
given the chance to talk about it ..... if you willing to design a pcb for a simple device like the P3a and follow all the mentioned rules above, and some others not mentioned in this thread is actually impossible ( trust me on this one been trying for 5 years in my spare time )
you may as well go for a double layer but then you are swimming in unknown waters like proximity where induction or capacitance between traces and layers will be impossible to evaluate properly for people that don't have experience and/or highly sophisticated equipment .
Conclusion is that you have to "keep" the rules but up to a certain point divided by symmetry /looks and all of it underlined with the cost factor ...
conclusion also is that people that exist in the diy often are bad in mathematics ( like me ) so the above equation is almost impossible to solve ....
happy regards
sakis
Rod Elliot P3A Layout - CriticsHide this!Advertise here!
Rod Elliot P3A amp noises tktran Solid State 75 23rd July 2016 03:35 PM
Rod Elliot P.68 Phase? samutacaratti Solid State 26 20th August 2014 04:39 PM
Rod Elliot P37? roger-k Solid State 21 7th October 2006 08:37 PM
Rod Elliot P3a boards stuffed FS! Mattyo5 Swap Meet 8 3rd October 2006 02:45 PM
Rod Elliot 100W PCB Layout bugbite2k Solid State 5 30th January 2002 06:32 PM
Copyright ©1999-2017 diyAudio
