Old 28th November 2011, 09:49 AM   #1
Send a message via ICQ to elvischan917 Send a message via MSN to elvischan917
Default Abnormal Clipping Need Help~~~
Hello everyone!
I just built this circuit and get this kind of abnormal clipping, can someone tell me what's wrong? What should I check?
One more question, should the max output voltage be higher than this level?
Supply Voltage just before clip is +/-47.5V
Schematic
Clipping Waveform
Waveform just before clip
Old 28th November 2011, 09:50 AM   #2
Just thanks for your help in advance ^_^
Old 28th November 2011, 10:15 AM   #3
astankov's Avatar
Probably problem in your VAS. Decrease if possible the value of R1 - make it as low as possible or remove it. R3 value also must be decreased. I had the same problem in one schematic and this solve it.
Old 28th November 2011, 10:51 AM   #4
Hi astankov~
Would you mind to explain how R1 and R3 affect this circuit? Would decreasing values of these two causing other issues?
Thanks!
Alvis
Old 28th November 2011, 11:08 AM   #5
649/669 are excellent driver transistors. They are not suitable where low current, high speed, low Cog, high hFE devices will allow better performance.
Don't use them in VAS, nor in Vbe multiplier.
You may need to increase Cdom, to account for the lower capacitance reflected through Q1
Q1 needs protection. Add a resistor between collector and ground.
124p ?
Is that 120nF?
Why won't 100nF or 150nF do in those decoupling locations?
The clipping shown reminds me of the odd behaviour of opamps that have their input taken outside the specification range. Some opamps reverse phase and other oddities.
regards Andrew T.
Old 28th November 2011, 11:43 AM   #6
astankov's Avatar
When I was first time simulating this schematic - My new design or updated old one I was using 68R resistor in the emitter of the main VAS transistor (first picture) and I had perfect sine and square wave response but in clipping just like your problem but in negative half of the wave. In your case is in positive wave because of the different polarity of the transistors. I started searching the problem and found it - when you decrease the value of 68R resistor in the emitter of the main VAS problem started to disappear and it disappears completely when resistor is removed (second picture). That was my experience with this problem. I can't technically explain you why this happens only to point possible solution. You can try it or not this is your decision.
Regards!
Andrey.
Old 28th November 2011, 12:52 PM   #7
Originally Posted by elvischan917 View Post
Hello everyone!
Schematic
Clipping Waveform
I think Q3 and Q4 do not form a proper current mirror.
A resistor should be added between base and collector of Q3.
Old 28th November 2011, 01:18 PM   #8
Q3 & Q4 are shown as a correct current mirror.
The trimmer VR @ 200r is higher than normal, but it will still work.
Have a look at what voltages and currents exist around the VAS & EF when clipping.
Compare those voltages and currents to what happens around the input LTP when clipping.
regards Andrew T.
Old 29th November 2011, 09:34 AM   #9
Regards!
Andrey.
Thanks for your help. I tried to short R1 but then there is an oscillation around 7MHz at the output of VAS. I did not check the final output yet. I will try it further then.
Thanks!
Alvis
Old 29th November 2011, 09:39 AM   #10
Hi Andrew,
Thanks for your advice! But what does EF and LTP means?
By the way, I have measured the positive supply voltage at clipping, please check and see any clues. Its absolute value is about 1~2V lower than the negative supply voltage, and, the negative side voltage supply waveform is not distorted.
Thanks!
Alvis
File Type: jpg Positive V supply at VAS when clipping.jpg (22.9 KB, 110 views)
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 01:03 AM
Abnormal hearing Wavebourn Everything Else 3 4th September 2009 05:17 PM
A question about voltage abnormal Frank J.Y. Lin Solid State 6 9th January 2007 11:11 AM
What is clipping? guitargully Solid State 5 25th February 2004 08:24 PM
Abnormal load time Netlist Forum Problems 8 21st July 2003 05:05 PM
Page generated in 0.12341 seconds (82.42% PHP - 17.58% MySQL) with 11 queries
