#21 | |
"If only we'd known that iPads would unite to enslave the people they entertained." |
#22 | |
Perhaps I should've gone straight to 2200/3300uF... but I will audition it with the 1000uFs and see what it sounds like in terms of bass response...
#23 | |
Wonder if it's worth checking the old carbon resistors for drift? And now I'm terrified of tin whiskers lol
#24 | |
With a DVM you obviously don't have to pull the shunt to read the O.T. bias, just use clip leads to jumper the 0.47 ohm resistor. The 1000 ohm/volt meters your average hobbiest (like me) had in 1964 had would have changed the readings considerably.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 |
#25 | |
The AFxxx transistors were often used in radio front ends and ran at very low voltages and currents where the problems would be very noticeable. It's possible (and I'm only guessing here) is that the currents and voltage swings when used as a driver transistor may well prevent these "whiskers" forming. Enjoy the amp
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#26 | |
But yes, they seem to be working and so I will leave well alone... although germanium transistors are obsolete as betamax, I still find it a bit baffling that there aren't any on the (niche) market, and replacing them means finding originals from the early 60s! A shame!
#27 | |
![]() You can still get germanium devices although the choice is limited. I built this from old parts I had, GERMANIUM Single ended Class A Headphone Amp.
#28 | |
Why should they sit on the shelf when you can put something nice together out of them?!Just finished the rest of the electrolytic recap... yet to test it as it's a bit late/ Also wired the voltage selector out and hard wired for 250V (I don't know why I have a habit of doing this, I just find them annoying!) and removed the absolutely pointless 'AC Outlet' socket... one less bunch of needless mains leads running through the loom! Starting to look neater... was going to tackle the inputs/switches but my mind exploded when I had a look and so I'll leave it for a day I actually have the mental energy ![]() ![]() Here's how it looks now... fingers crossed it was worth it. A small amount of the old electrolytics had leaked/were looking corroded around their bases...
"If only we'd known that iPads would unite to enslave the people they entertained." Last edited by bleachershane; 6th December 2011 at 11:18 PM. |
#29 |
Last year RS in UK had Germanium signal transistors at about L2 each. Or was it RB? whoever is #2 distributor over there, not Tandy corporation. Not that you know you need them yet. The only thing in the US (newark, mouser) was germanium doped silicon RF transistors, which is something else entirely.
FM radios used to run off the power outlet before they invented the power socket strip. You could turn off the whole system at your control hub (the amp). My PAS2 preamp had the power amp plugged into it for decades, one switch did it all. You don't need a preamp, it is all built into this unit. With the attendant selector switch problems.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 Last edited by indianajo; 7th December 2011 at 12:38 AM. |
#30 | |
| Leak Delta 70 - Attempt DIY, Overhaul or buy another amp? | Sherloq | Solid State | 30 | 28th March 2012 12:32 PM |
| Leak Delta 30 Amplifier - One Channel Down | Wage Slave | Solid State | 2 | 30th September 2010 10:53 PM |
| Leak stereo 20 modification | Gudmund | Tubes / Valves | 55 | 28th March 2010 06:00 AM |
| Replacement Transistor for Leak delta 30 | renjiish | Solid State | 3 | 18th August 2008 02:08 PM |
| Mods on leak stereo 20 | bronto64 | Tubes / Valves | 22 | 26th April 2004 08:27 PM |
