Old 27th November 2011, 03:09 AM   #1
htgeek is offline htgeek  United States
Default Burnt power transistor
I have a 200w power amp that wasn't working so I opened it up and found that a transistor, 2N4403 was cracked and two power transistors, 2SC3298's were black and burnt.
I have attached a picture showing T13 with a red circle around it that had cracked and T11 and T14 with the orange circle are the two burnt power transistors. Could T13 being cracked cause a short somewhere that would cause T11 and T14 to burn out, everything else on that board looks fine.
Old 27th November 2011, 03:53 AM   #2
In a DC coupled amp problems usually travel from output towards the input. It's difficult to say what-all might have gone wrong and what parts are now bad. That's why test equipment exists! You need to check each and every active device, and I'd check all the passives too. The chances of fixing this by visual examination alone are low.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 27th November 2011, 11:44 AM   #3
djk is online now djk
djk's Avatar
"Could T13 being cracked cause a short somewhere that would cause T11 and T14 to burn out, everything else on that board looks fine. "
No, T13 is a protection transistor.
Most likely T7, 11, 10, and everything to the right should be replaced, check all the emitter resistors too.
Fire the amp back up with a 75W lightbulb in series with it.
C48 may also be damaged.
Parts are cheap, time is not, and some stuff may test OK and still be damaged.
Candidates for the Darwin Award should not read this author.
Old 27th November 2011, 11:57 AM   #4
jaycee is offline jaycee  United Kingdom
Phone jacks for speaker outputs - almost certainly speaker plugged/unplugged while the amp was on, shorting the output. Do yourself a favour and replace the phone jack with a Speakon connector!
T11 is the bias control device, so that blowing up has probably turned on full bias and killed the drivers (T14/T15) and outputs (T16-T19). T13 is a VI limiter transistor and has probably killed itself trying to shut down the output stage. T7/T10 might also be toast.
Transistor power dissipation Neutrality Solid State 2 19th December 2010 04:41 PM
need help with power transistor slackama Solid State 2 28th December 2009 02:39 AM
which power transistor is btr? space2000 Solid State 4 19th April 2008 02:01 AM
Power Transistor Difference? zox2003 Solid State 2 1st April 2005 12:30 AM
power transistor assembly(how to?) picchiatello Parts 17 29th March 2005 07:31 AM
Page generated in 0.07591 seconds (76.93% PHP - 23.07% MySQL) with 11 queries
