Old 26th November 2011, 07:33 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default don't try this AMP at home
BJT are not able to increase voltage because
hFE is less when tension is more
so BJT AMP make a compression of signal
for that reason
Voltage Amplification Stage is a toroidal transformer
and the gain of BJT AMP is 3dB
Note:
1. W2 - omitted (In case of many users have not enough skill and equipments to adjust the offset of amplifier - half value. Then omitted the W2 to make it simple).
2. R28 = 220 ohm in case of omitted W2 (viceversa shorth)
Adjustment:
1. Apply power but do not install power output transistors in this moment, adjust W1 to make 1K (FET source resistor) to 2.3---2.6VDC
2. Adjust W3 to set the voltage difference between pin 1 & 3 of power output transistor to 0.45V or less. Do not install power output transistor in this moment too!
3. Test the DC offset with W2. Install the power output transistors: the output DC offset is 25mV or less. Otherwise adjust W2
Adjust W3 and check the voltage drop of 0.22 ohm / 5W resistor. 10mV to 40mV (depends on effiency of the heatsinks) is ideal volatge drop.
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 26th November 2011, 07:41 AM   #2
Hi Stee
Respect where it is due.
Kind Regards
Ian
Old 26th November 2011, 07:49 AM   #3
destroyer X's Avatar
Default Stee always have interesting ideas
a very valuable guy to our community.
Va molto bene.
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 26th November 2011, 11:25 AM   #4
Stee's Avatar
2 X DIAMOND DIFFERENTIAL INPUT POWER AMPLIFIER KIT! | eBay
THANKS destroyer X
Old 26th November 2011, 04:30 PM   #5
a.wayne is offline a.wayne  United States
a.wayne's Avatar
China ebay seller, possibly fake parts at that price ...?
Old 26th November 2011, 04:48 PM   #6
JMFahey is offline JMFahey  Argentina
Maybe you are inventing a new Electronics here
What shall we do with the billion billion BJT voltage amps out there?
Old 26th November 2011, 06:45 PM   #7
Hmmm, sounded like nonsense to me too.....
Old 26th November 2011, 08:29 PM   #8
CBS240 is offline CBS240  United States
CBS240's Avatar
If the design is based on voltage constraints and current gain, you may have problems. Best not to design around variable variables like Hfe, Vbe or Vceo. You may have to pick and choose and will never find a replacement transistor that works without circuit modifications.
All the trouble I've ever been in started out as fun......
Old 26th November 2011, 08:41 PM   #9
Not to forget that Hfe(Beta) varies *very* little (if anything at all) with Vce, while it varies *a lot* with collector current.
As a side note I very much doubt that the expensive, complex and heavy solution posted above is as linear as a humble (20 cents) 1/2 TL072, set for 20X gain.
Looking for home audio / home theater speaker DIY or not? qualm Multi-Way 17 26th March 2012 03:30 PM
Convert a home amp (110v) to car amp (12v) jimmyvstc Car Audio 4 12th February 2009 05:16 AM
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
Pro amp to Home amp, mods advice please? matt09 Solid State 26 4th March 2008 07:21 PM
Home theater & Car Stereo .. TVP Swap Meet 4 12th January 2005 08:03 PM
Page generated in 0.09878 seconds (77.00% PHP - 23.00% MySQL) with 11 queries
