For the longest I've been trying to identify these resistors. I would like to find out the brand and model number if possible. Any help would be greatly appreciated.
They are metal film, light blue in color, and have a 6 band color identification. They are approximately 7mm X 2.5mm. The closest that I've found are the old Roederstein Resista MK3 resistors. Here are some pictures: |
#2 |
Look like Dale's. Don't know model numbers.
Doc Like these Vishay/Dale's: Digi-Key - BC27KW-2TR-ND (Manufacturer - PR02000203272FR500)
Ne timeas a facie mulierum ea ignorare Last edited by thaumaturge; 25th November 2011 at 08:58 PM. |
#3 |
Philips SFR25 or nowadays VishayBCC SFR25 5% metal film.
#4 |
Hi
The Last two bands look like brown and red in the piccy. If that is correct . Brown = +- 1% Red = 50ppm . Im Guessing you already know that. |
#5 |
Thanks for all of the help. Yup, the last two bands are brown and red on all of the resistors. They are 1% and 50ppm. I suppose this rules out the Vishay BC Components SFR25, as they are all 100-250ppm, even though visually they look very similar. Also, the SFR25s are marked with only either 4, or 5 band color identification, whereas the mystery resistors are all 6 band.
Any other ideas, or suggestions? |
#6 |
I think I've found them. Thanks to Jeronimo2003 for pointing me in the right direction. I believe they are Philips MRS25. Here is a picture from an eBay seller, they look identical and have identical specs:
#7 |
I am sure they are of german origin, but I can't remember the exact manufacturer.
#8 |
hello.
this could be a (vishay) beyschlag res, mbb0207 (1%, 0.6w,50ppm). here is a picture of a new one with rohs conformity. |
#9 |
Hi
Out of intrest what are these resistors installed in. Im guessing with the simple exterior of resistors lots will look exactly the same. Regards Ian |
#10 |
I found them! They are Philips MRS25 and are now made by Vishay. They look and spec identical. Thanks to Jeronimo2003 for pointing me in the right direction. Here's a picture of some for sale on eBay:
| memphis resistor identification | ampjunkielikeme | Car Audio | 4 | 16th July 2011 08:44 PM |
| Resistor type identification | SolderN | Parts | 6 | 28th October 2009 09:16 PM |
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| Resistor identification in Kenwood B7 Amp | matthewdenard | Chip Amps | 0 | 23rd April 2005 07:55 AM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| Page generated in 0.08648 seconds (82.77% PHP - 17.23% MySQL) with 11 queries |
