Old 25th November 2011, 11:02 AM   #1
kees52 is offline kees52  Netherlands
Default very heavy J-fet
I found this!
little expensive but heavy 48 ampere 1200 volt j-fet.
http://semisouth.com/wp-content/uplo...045_rev1.3.pdf
high end audio
http://www.radiolocman.com/news/new.html?di=107175
Old 25th November 2011, 11:31 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
These devices have fairly high capacitance until they start seeing some significant voltage across them. However, if Nelson can make them sing, they are going to be popular.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 25th November 2011, 11:38 AM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just send me some ......... and you'll never hear again for them
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 25th November 2011, 11:42 AM   #4
homemodder's Avatar
Wonderfull devices for making outputstages, now if there was a complementary it would be even beter. Together with a medium to low power device it would be perfect for making great circuits.
Old 25th November 2011, 12:16 PM   #5
But where can we buy them and how much do they cost?
Old 25th November 2011, 01:02 PM   #6
Farnell / Electronic Component Distributors / Suppliers / Electronics, Electrical Parts, Electrical Components and Wholesale Electronics. expensive if high amperage.
Old 25th November 2011, 01:19 PM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Interesting. But expensive as new technology usually is. For now I will probably stick to my error correction vertical mosfet output stage. I used to be in the nice linear BJT camp but have discovered from experimentation and application that, IMO, despite being much simpler to use they are not the best output device. Perhaps in the end this technology will usher in an age of affordable and available power J-fets once again. We can all only hope.
All the trouble I've ever been in started out as fun......
Old 25th November 2011, 01:33 PM   #8
cfb is offline cfb  United States
Default SJDP120R045 - JFET
For those of us in the USA seems like Newark will carry them at $86 each. Not in stock yet but the link to order is;
SEMISOUTH|SJDP120R045|JFET, SILICON CARBIDE (SiC), N | Newark.com
Old 25th November 2011, 01:34 PM   #9
you mean error correction like mine hybride, I have not build it yet, but without feeback distortion is very low.
Old 25th November 2011, 01:39 PM   #10
this is the audio version SJEP120R100A 17 ampere, cost in holland 17.40 euros
and the audio version SJEP120R063A 30 ampere cost in holland 35.70 euros.
in fact these jfets are not real jfets because of the forwarded vgs, but some kind of enhanced, but with low on viltage of max 1.25 volt, so it seems a little bjt like voltages (twice as high at highest) so very interesting for testing.
Di-fet sub for J-fet? semi932 Analog Line Level 7 27th June 2010 03:39 AM
Threshold FET 10/pc Phono Stage Preamp Schematics aka FET 10pc, FET-10pc, fet ten/pc krellkraver Solid State 1 8th February 2007 03:05 PM
Which FET can replace K373 FET? Mrpong Parts 2 7th April 2006 11:37 AM
Fully complementary FET-in FET-out design Bensen Solid State 36 7th January 2006 09:21 AM
Yikes!! FET Substitution? Could use some FET Guru's here... EchoWars Solid State 15 9th February 2004 07:08 PM
Page generated in 0.11002 seconds (71.09% PHP - 28.91% MySQL) with 11 queries
