Hello there. I need to run a pair of floorstanders from 2 amps (not at the same time) and be able to switch between the 2 so as not to cause damage to either amp. I think Beresford market something like this.
Does anybody know of a kit that will enable me to do this, please? Regards, Les G |
#2 |
Russound AB-2.2 Table top A/B Selector - Compare Prices and Reviews on Russound AB22 Engine Parts at PriceGrabber
http://www.stereo.net.au/forums/show...-switching-box http://sound.westhost.com/absw.htm Last edited by lduarte1973; 24th November 2011 at 09:23 PM. |
#3 |
I'll look it up. Thanks.
Les G |
#4 |
#5 |
#6 |
If it is only the amplifier outputs you wish to swap, any speaker protection relay kit will have changeover contacts that can be used for this. You only need to ensure that any DC protection circuit is disabled and it triggers simply from applying the rated relay coil voltage of 12, 24V etc,
Simpler still, use just one basic DPDT switch. With a high current rating like 15 amps, these are just as effective a solution and needs no extra parts or power. If that is all too hard to look for, electrical power switches are just as good if DPDT (Double pole - Double throw) as you require. You may even see a suitable plastic box to mount it in if that is necessary.
regards |
#7 |
Brilliant. Thank you all for your suggestions. Definitely food for thought. I'll get my thinking cap on and see which design fits my setup best.
Thanks again |
| Why do most 2 channel amps run hot when bridged? | chipper | Car Audio | 8 | 19th September 2010 05:00 PM |
| How to connect 2 amps to 1 pair speakers? | ransom peek | Multi-Way | 1 | 10th October 2006 07:56 PM |
| Puzzler!! Using 3 amps w/ 1 pair speakers | ransom peek | Solid State | 11 | 18th March 2005 04:50 PM |
| How to switch single pair speakers across multiple amps? | ransom peek | Multi-Way | 0 | 21st February 2005 03:30 PM |
| Page generated in 0.08492 seconds (76.76% PHP - 23.24% MySQL) with 10 queries |
