help... i'd like to know which is better capacitor connection on a quasi amplifier?
power supply using 2 - 4700uF/ 50V or 4 - 2200uF/ 50V? |
#2 |
Check the ESR values of capacitors.
If you double the number of capacitors, in parallel, the total ESR value should be caclulated according. If you use 2 22000uF in parallel the total ESR value will be halved. The lower ESR the better |
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| Split +/-12V Phono preamp Power Supply | partialresponse | Power Supplies | 11 | 23rd October 2009 06:00 AM |
| how to use 30 volts DC instead of split power Supply | ali_moinuddin | Pass Labs | 5 | 2nd April 2008 10:34 PM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 06:09 PM |
| split power supply | ocool_15 | Chip Amps | 3 | 16th December 2004 10:39 PM |
| Page generated in 0.05983 seconds (66.00% PHP - 34.00% MySQL) with 10 queries |
