Pioneer A88X Schematic.zip
hi all iwas woundering if anything can be done to this amp,op amps caps etc.. |
#2 |
going to try the opamps first,will try opamp2604.
#3 |
These are pretty nice amps, nonswitching outputs high current output capable and sound pretty good. Considering the age of the amp I would recommend you rather start with replacing the caps especially the ones in the power supply circuitry and the main rectifying caps. After that you could also have a look at the caps in filtering and coupling circuitry depending on what was originally used and if you have access to a scope the compensation ones too. A bit of a warning, be very becareful as to not damage the nonswitching IC, will be very hard to replace.
#4 | |
#5 |
Like for like is a good idea but in the case of the rectifying caps Id probably go a size or two up, that is space permitting on pcb. Pioneer usually used better than standard caps so Id get some good ones for replacement. Since youre in the UK and can easier purchase, have a look at BNC slitfoils, excellent power supply caps.
Wima polyprops are very good yes, but this again is size permitting, these caps are much larger, otherwise go with high quality electros. It also depends on what you want to spend to restore the amp. |
#6 |
op amps fitted,big difference in sound.
#7 |
That's good to hear.
Did you go for the OPA2604 ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#8 |
| pioneer a-88x recap,what else could be done | paul.42 | Solid State | 0 | 23rd August 2011 05:47 PM |
| can my sony amp be tweeked | paul.42 | Solid State | 1 | 10th August 2011 05:51 PM |
| Page generated in 0.09098 seconds (75.56% PHP - 24.44% MySQL) with 11 queries |
