Hello
have seen 2sa970 - 2SC2240 will going obsolete, but there is a TOSHIBA SOT23 Model with same technical specs. Does somebody know device number ? |
#2 |
Hi ,
maybe replacement :2sc3324/2sa1312. Z.B. |
#3 |
SOT 23 has smaller Pd. If your replacing a part in an existing circuit be sure to check bias and power of the TO-92. I would not go above 60% Pd max for reliability purposes, IMO.
All the trouble I've ever been in started out as fun...... |
#4 |
I would prefer that Pq <<50% of Pmax
regards Andrew T. |
#5 |
Yes, perhaps <50%. When I design with SMD and expect to reach the that limit, I like to draw a larger copper area for the collector pin so you don't have to de-rate quite as much. This extra heat sinking of the collector pin bumps up reliable Pd a bit by lowering die temperature and so less de-rating. The datasheet for SMDs usually specifies a certain copper area with specific copper thickness and standard FR-4 PCB material. If it is not mounted as designed for SMD PCB pads, I wouldn't go more than 30% especially for the higher voltage ones. A small current spike can destroy it quickly.
All the trouble I've ever been in started out as fun...... Last edited by CBS240; 21st November 2011 at 03:26 PM. |
#6 |
Not many SMD types generally, are rated to 120V Vce. Do you need a high voltage type? .
regards |
#7 |
However, these look good
http://www.fairchildsemi.com/ds/FJ/FJV992.pdf http://www.fairchildsemi.com/ds/FJ/FJV1845.pdf
regards |
#8 |
2SA1163/2SC2713. As far as I can tell, the plots on the spec sheet are the exactly the same as 2SA970/2SC2240. Of course, the power dissipation is smaller, though.
Have fun! PS. I have some of these in hand. Drop me a PM if you want to try them out. |
| spice models for 2sa970/2sc2240? | bmcevers | Solid State | 14 | 23rd July 2010 06:56 AM |
| transistors 2sa970/2sc2240 | pdul | Parts | 8 | 14th June 2009 06:59 PM |
| WTB: 2SA970 & 2SC2240 within Canada | abzug | Swap Meet | 9 | 16th January 2008 01:23 AM |
| Spice models of 2sa970 and 2sc2240 | hjelm | Parts | 4 | 16th February 2004 09:27 AM |
| 2SA970 & 2SC2240 pinouts or datasheets? | JoeBob | Parts | 2 | 8th October 2003 12:04 AM |
| Page generated in 0.08862 seconds (75.90% PHP - 24.10% MySQL) with 10 queries |
