Old 20th November 2011, 01:21 PM   #1
Default Marantz SR4120 not holding station presets
MArantz SR 4120 AM/FM receiver isn't holding station presets when powered completely off for a few days.
The unit is capable of being put in a standby mode with the remote control and then powered up to use and then put back into the standby mode when not used. The owner is powering the unit completely off via the power button on the front of the unit when he is done using it instead of putting it in the standby mode with the remote control.
My question is ...is it normal for the unit to loose AM/FM station presets when powered 100% off for a few days or does the unit have a problem? Isn't the normal mode of operation for the units made in the last 5 or 6 yrs to be parked in the standby mode when not used so they retain settings?
Old 20th November 2011, 02:10 PM   #2
DF96 is offline DF96  England
What does the manual say? Some items lose settings when switched off, some have a memory-retention battery (which might have failed), and some use non-volatile memory.
Old 20th November 2011, 05:02 PM   #3
sregor is offline sregor  United States
Look for battery or "super cap" on tuner or display controller board. Super caps are large (.047 Farad or higher - F not uF or mF or nF or pf and 4 to 5.5 volts (usually) about half an inch (1.2 cm) tall and 0.5 to 1.5 inches (1.2 to 4 cm) in diameter. Information should be in manual. YMMV
Steve
Old 20th November 2011, 06:40 PM   #4
Was able to download a manual off the internet. It says that upon power loss it can retain presets up to a week. Will try to take a look see. Just wondered if anyone knew for sure.
Old 20th November 2011, 08:26 PM   #5
"Up to a week" probably means either a supercapacitor or a rechargeable NiCd battery.
Old 23rd November 2011, 05:17 PM   #6
Try C901 0.1 F 5.5 volt "gold cap" (notation on main board in manual). If searching for parts, often called super caps.
Steve
Clarion 2 yellow wires = no presets memory?? metaverse Car Audio 1 15th January 2009 08:30 PM
New Pass Integrated? Nelson holding out on us? lgreen Pass Labs 50 4th April 2008 07:14 PM
Onkyo TX866 Presets lincolns6 Solid State 0 31st December 2005 01:08 PM
Soldering and holding Large wires ! wytco0 Parts 7 2nd November 2004 04:23 PM
TDA 1514A not holding its own RIC Chip Amps 23 30th September 2004 04:39 AM
Page generated in 0.15939 seconds (35.94% PHP - 64.06% MySQL) with 10 queries
