I have a condensing microphone that requires the normal 48v phantom power, and a i want to make a preamp for it that unbalances the signal so i can use it with my pc.
I've pieced together what i know and come up with the following schematic. Just want to know if there are any glaring issues with it, and also a basic way to drop 48v to 12v. any help would be great! thanks guys. |
#2 | |
Having done something similar (but a long time ago) I found that with AKG and Sony condenser mics, a preamp gain of 40-50 dB (I use 46) will cover nearly all the bases with very good results. The only time it was too much was in a small room with a brass band. Dang that was LOUD. You're not showing any protection diodes for when the phantom power is turned on. That 48 Volt surge into your opamps may very likely kill the inputs. Also you want to add some RFI filtering on the inputs. I was recording in a church near O'Hare in Chicago and while my stuff was fine, another guy was there and he was picking up the control tower. You don't want things like that. As for your power supply you'd have better luck with 3 supplies - dual transformers or one with dual secondaries. They all need to be well regulated. On my preamp I'm running +/- 15 to the opamps along with the 48. Good luck G² |
#3 |
someone know where can i found an review of opamps to see which to choice? i ordered a few that 1570, but want to test different ones to see wich will be works better, i wwant to build an pre amp with 2 fixed values 20db 40db 60db.
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| 'Tube' preamp bad for measurement mic? also Apex mic question | morbo | Multi-Way | 10 | 23rd March 2005 10:19 AM |
| What mic preamp for Behringer testing mic | The Paulinator | Multi-Way | 1 | 6th April 2003 07:02 PM |
| Mic Preamp from X preamp circuit? | e.lectronick | Pass Labs | 2 | 13th November 2002 02:01 PM |
| Page generated in 0.07399 seconds (73.27% PHP - 26.73% MySQL) with 11 queries |
