Old 17th November 2011, 08:13 AM   #1
Default CFP Buffer
What are you thinking about this circuit of CFP buffer? The different is that I remove resistors on emitter on the driver transistors and they always stay in class A mode. What are you thinking about temperature stabillity, i think to put all transistors on one copper heatsink?
Whether it will works good and stable?
Old 17th November 2011, 09:19 AM   #2
ilimzn is offline ilimzn  Croatia
Couple of things missing from the schematic...
Missing emitter resistors for the output makes it NOT a CFP...
The DC servo relies on the internal impedance of the source, which may be a problem under realistic conditions.
Why regulate the DC rail that powers a current source since the current source attenuates AC from the rails by several orders of magnitude?
Old 17th November 2011, 11:07 AM   #3
Originally Posted by ilimzn View Post
...Missing emitter resistors for the output makes it NOT a CFP...
Yes, that is the idea. What are you thinking about this?
Ok, what is your suggestion?
I'm regulating the DC because i want max effectiveness and stability. I'll try to remove a servo.
What are you thinking about termal stability of the circuit? Alll transistors will be on one copper heatsink.
Old 17th November 2011, 11:32 AM   #4
Originally Posted by whitesnake View Post
..........What are you thinking about termal stability of the circuit? Alll transistors will be on one copper heatsink.
All 4 output devices can be on a single heatsink.
The two drivers must be electrically isolated from that same heatsink.
regards Andrew T.
Old 17th November 2011, 12:35 PM   #5
kimk is offline kimk  China
yes,With Q13, 14 temperature tracking can be done.
Old 17th November 2011, 12:46 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
I don't think it will work (well, ok, maybe for a few milliseconds ).
There no current limiting in the drivers. The servo only regulates the DC output level, but the drivers can and will conduct large currents meaning the output devices will conduct even larger currents.
You should use emitter resistors in the drivers as a minimum. They can still be in class A, of course.
Another option is to move the emitter resistors from the output devices to the CFP side that connects to the output.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 17th November 2011, 07:09 PM   #7
Bigun is offline Bigun  Canada
Bigun's Avatar
You need to isolate the source from the amplifier by using an input capacitor - this will act as a dc-block and allow the dc-servo free reign that it needs.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
CFP diamond buffer output stage with vertical FETs, thermally stable? Russ White Solid State 5 1st January 2008 04:16 AM
Question(s) about CFP. Justcallmedad Solid State 94 20th September 2005 10:08 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Page generated in 0.10052 seconds (72.68% PHP - 27.32% MySQL) with 11 queries
