Old 16th November 2011, 12:54 PM   #1
Default What is difference between two circuits
Old 16th November 2011, 12:59 PM   #2
In the first circuit you will have only 50uF decoupling between pins 4 and 8.
Old 16th November 2011, 01:07 PM   #3
If so, is it better the second circuit, the circuit capacity is also simple.
Old 16th November 2011, 01:29 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
In the second circuit you can still have supply ripple and noise on the supply lines that can get into the circuit. You can also still have coupling via the supply that can under circumstances lead to oscillations.
So you should always use the circuit 1, and then add circuit 2 if you want.
But it is important to get clean supplies referenced to the signal reference, and that normally is ground.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 16th November 2011, 03:00 PM   #5
DF96 is offline DF96  England
The second circuit does not deal with common-mode noise on the supply rails, but only differential-mode noise.
Old 16th November 2011, 03:36 PM   #6
I can see that appears to be case but surely that is not the point if
the purpose of the decoupling is to decouple voltage rails to ground,
which it is I believe, rather than to each other, which it usually isn't.
As DF implies the second circuit has effectively 0uF for common mode.
The first circuit doesn't care about common / differential signals, and
as I understand it should always be used to guarantee stability.
I can't see the point of the second circuit.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 16th November 2011, 07:09 PM   #7
CBS240 is offline CBS240  United States
CBS240's Avatar
Since the PS supply caps, input, and output of the op-amp are referenced to gnd, so must the de-coupling caps or the circuit is not completed. IOW, the supply pins of the op-amp must have AC reference to gnd via the de-coupling along with the rest of the IC or instability may take place.
All the trouble I've ever been in started out as fun......
Old 17th November 2011, 02:20 AM   #8
Unfortunately I do not have equipment, which have the equipment to an experiment, the results made ​​up better, I think just a noise to provide a capacitor discharge circuit diarrhea, do not know that understanding correct?
mixer circuits jonathanmatenga Multi-Way 1 9th August 2007 07:01 PM
Connecting Virtual Ground Circuits with True Ground circuits?? Minion Solid State 1 12th February 2007 01:28 AM
Difference in performance between these 2 circuits? fluckscapacitor Solid State 16 19th June 2006 06:14 PM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 12:50 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 11:27 AM
Page generated in 0.09386 seconds (76.39% PHP - 23.61% MySQL) with 11 queries
