Hi all - I'm new here, but I hope that my question is reasonable straight forward. I have a 20 year old Rega Elex amplifier (yup, 20 years old - it was the first run with the purple Rega logo) that has a problem with the right channel speaker output.
Independent of the volume pot and the selector pot, the right speaker crackles/hisses with no music making it through to that channel. I have a pair of heaphones attached to the tape out, and the amp provides a perfectly good output there. Which component should I be looking at that may be causing this? Anybody have experience with this amp? |
#2 |
Could be a dodgy connector, a dry joint or similar, sometimes the power amplifier input transistors go noisy, unusual though. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
Thanks sreten. I'll take a look over the right channel. I've just connected it up again, and realized the it is in fact amplified by the volume pot, but the noise/crackle is reasonable loud with the volume pot at zero.
I think the input is fine as when listened to via the tape out all is sounding good. |
#4 |
first off, with an amp that age, shotgun replace all electrolytic capacitors. it could well be a bad coupling capacitor causing this problem.
#5 |
Thanks jaycee. You're right - are they roughly 2000-3000 hrs use? If so, they would be well overdue for a change. Can you recommend any particular type/supplier?
[edit] Are these any good? Link [/edit] Last edited by pphilpot; 15th November 2011 at 02:18 PM. |
#6 |
Having looked at the schematic, it seems the preamp stage is passive - just a selector switch and the volume pot. So you've got a more serious problem I'd say. I'd look for dry joints but i'd say its probably more serious.
I'm not sure what level of expertise you have here to suggest further. |
#7 |
Panasonic are good brand capacitors - also look at cpc.farnell.com
It is right that they're about 2000-3000 hours of use. After 20 years, they are indeed overdue for replacement, especially if they're only 85c rated. |
#8 |
Sorry jaycee - so I should definitely replace all 2.2uf circled in green, but what about the 1000uf and 10000uf circled in magenta? Would they be any specific quality?
Many thanks in advance. |
#9 |
The magenta ones are power supply capacitors... replacing those will help with sound quality but they wont be fault related.
#10 |
Ooh, that looks like a lot of soldering. Be careful out there. Use a decent soldering iron and desoldering pump. If you are rusty, practice your technique on something else before starting off.
| Does anyone have some idea about Rega Elex amplifer? | wbhifi | Solid State | 62 | 29th September 2011 09:21 PM |
| Repairing a Rega Elex Integrated Amplifier | TATER1971 | Solid State | 4 | 29th September 2011 12:58 AM |
| Rega Elex service manual needed | harhaug | Solid State | 7 | 12th February 2011 01:50 AM |
| Rega ELEX runs hot | mashley_nad | Solid State | 0 | 10th January 2011 11:59 PM |
| Need Rega Elex Schematics | Lewis Moon | Solid State | 6 | 6th September 2010 07:41 AM |
| Page generated in 0.08889 seconds (80.41% PHP - 19.59% MySQL) with 11 queries |
