Just finish my first JLH-2005. The circuit is from this link:
The Class-A Amplifier Site - JLH Class-A Update schematic and pcb attached. A few thought about the design 1. The original 1969 design use 2N3055 as Q1 and Q2. Then changed to MJ15003. I'm thinking of some other subsititutes such as 2N3773, MJ21194 or 2SC5200 2. Can I use 2SA1358 as replacement of BD140? it's complementary of 2SC3421. 3. How to set the value of VR1, VR2 and VR3? in other words, what current should those 3 current sources be? 4. Is the large polygon pour on PCB good for audio amplifier?
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me Last edited by siliconray; 14th November 2011 at 05:58 AM. |
#2 |
Hi Siliconray........you might think about moving this to the big JLH thread as you'll then get all the '69ers and '96ers (and every other version of it his great work) who will more likely appreciate your own construction...... just a thought...cheers, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#3 |
OH...good suggestion. I will post in that thread. But how to delete this post?
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me |
#4 |
I have reported post3. You should see a closed thread notice, or maybe a deleted thread.
regards Andrew T. |
#5 |
As if by magic...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Marconi 2005 | jartiili | Equipment & Tools | 2 | 10th November 2010 07:27 AM |
| Sears SP-2005 | CivicProtection | Multi-Way | 20 | 11th February 2010 02:18 AM |
| Full-tube 2005 | timothy | Full Range | 6 | 14th June 2005 05:36 PM |
| Seen at Home Entertainment 2005 | jackinnj | Analogue Source | 0 | 2nd May 2005 11:56 AM |
| Maf 2005 | gonefishin | Multi-Way | 2 | 31st May 2004 12:59 PM |
| Page generated in 0.08327 seconds (85.11% PHP - 14.89% MySQL) with 11 queries |
