I'm looking for a tech in Toronto willing to help me repair and troubleshoot an old friend. This amp worked flawlessly up until a few days ago when it started blowing fuses. I only had a 4 pack of the MDX7 style fuses as replacements so after the second one blew I removed the amp for inspection.
Inspection revealed nothing, no real burnt spots, and no evidence of real damage. There are apparently mods available for this amp to improve performance and would be a plus to add these features also while repairing. Any young tech willing to give it a once over or willing to give me a list of what needs to be repaired I'd be grateful. Hell there may even be a few beers in it for you I really don't want to scrap this amp, but am not willing to pay tech prices when I can repair the issue once the issue is found. Thanks for any help in advance.
What was that?... I can't hear you I have a line array filling my ears. |
#2 |
If these are glass fuses, are they blackened or did the fuse element just melt?
Blackened = dead short Melted = overloaded but not shorted The first places to look in an amp for shorts are the rectifiers (easy to check, usually blacken the fuse when the short), the large filter caps and of course, the output transistors. |
#3 |
Yup big crackly spark ending in a blackened fuse. Something tells me it's the supply caps because when I opened the amp up, and re-installed a fuse to see if I could see/hear anything the power supply transformer hummed and then a spark from the fuse.... I'll try and do some measurements and post them here, although I'm no tech I do have a DMM and screwdrivers LOL. I'll check the caps, rectifiers and the output transistors and get back to you people on any readings.
Thanks again.
#4 |
It could be anything with a direct connection to the main voltage rails. Got pics of the insides?
The transformer humming is due to overload as well. |
#5 |
I'll take pics and post later.
#6 | |
-Evaluate press for cracking and recommend solution $50,000 The company president calls the engineer and questions how such a simple fix could possibly be worth that much. He then insists the engineer submit an itemized bill for the work. Several days later they received the revised invoice: -Travel by car to your plant and back $ 75 -Inspect machine to determine cause of failure $ 500 -Draft and provide sketch defining repair procedure $ 250 -Knowing why gussets were needed and where to put them $ 49,175 -Total amount due $50,000 The bill was promptly paid in full.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
#7 |
Fortunately you have a poor engineering student here that feels your pain and is willing to help.
#8 | |
Yup, getting paid for what you know is what we all live to do correct? But this is DIY audio, not a referral service to a technician style board. I understand that sometimes you get what you pay for, but in this circumstance I feel it necessary to remind you that I am not willing to pay a tech if the repair can be done by myself DIY style. If in the end I feel the repair needs to be done by a pro, I have a board here available that can provide me with some pretty capable hands. But until I deem this impossible I'd rather try and rectify this myself, and if help is provided then I greatly appreciate the help.... And I did mention beer and I'll even provide tunes LOL so it's not so much a free ride.
Hey, thanks for the comment it helped out a great deal .Quote:
#9 |
Do some searches on this forum. I recall several posts saying that the Carvers were a 'different type of beast.' The average serviceman may have troubles with them and they are not too DIY-friendly. Look up posts by Anatech, a tech with a good deal of experience with Carvers and is fairly local to you (Georgetown). I'm not sure how is health is these days as I haven't seen him post in some time. From my reading on this forum you are likely looking at a problem that requires someone quite a bit of experience (ie, not a DIY-er).
Steve. |
#10 |
The fuse that is blowing it is the main fuse. If it is then you possible have a bad rectifiers in the power supply. If it blowing the main fuses. Regards, tauro0221 |
| Carver M-500T Bias adjust question | flyingtele | Solid State | 2 | 24th November 2011 03:24 AM |
| Carver M-500t and C-1 for sale | danno | Swap Meet | 1 | 23rd August 2010 10:41 PM |
| Carver Repair 101 ???? | Zero Cool | Solid State | 0 | 20th February 2008 08:48 PM |
| Carver M-500t Protection Relay | solderhead | Solid State | 24 | 30th September 2007 09:36 PM |
| Help for Carver repair | blank527 | Solid State | 0 | 6th November 2003 10:06 PM |
| Page generated in 0.12274 seconds (79.55% PHP - 20.45% MySQL) with 11 queries |
