Hi everybody,
I just finished my 5.1 PC amplifier on the breadboard and it is working great so far. If anybody is interested I can post a schematic. Its basically the Earle Eaton headphone amplifier with higher supply rails (+/-21V) and the bias resistors replaced with current sources, it should give around 18W per channel. The amplifier powers fairly expensive speakers (or my Beyer dynamic headphones) so speaker protection is a must. So far I'm using 100uF NP output capacitors to protect the speakers but these give a corner frequency of 198Hz and already gobble up plenty of board space. Bigger capacitors are no option because the whole amplifier has to fit in a fairly small monitor stand box. I spent hours searching for a simple and small DC detection circuit but to no avail so far. Since 6 channels need to be protected, the board size and complexity piles up with the rectifier diodes, filter caps and transistors needed. What is needed is a simple circuit either using a special IC or making use of highly integrated circuits such as SMD quad op-amps. The special IC's I found on ebay are for stereo-use only and still require a fair amount of additional components. Maybe it is possible to use a PIC controller to sample the outputs with its integrated A/D converters, then shift & sum up the values to see if any DC is present? Any suggestions are greatly appreciated. Best regards, macplauder |
#2 |
#3 |
3 dpst relays (double pole single throw) can isolate all 6 outputs.
A 5.1 amp system is probably working from low voltage rails with lowish capacitance in the Power supply. The relays may survive a serious fault interuption. One detector system to activate all 3 relays simultaneously, with a big RED flashing LED to tell you it is in protection mode, should not use too much space. I think pic and some of the discrete detectors can run with 6ch inputs .
regards Andrew T. |
| Amplifier and speaker protection circuits | Peter Daniel | Pass Labs | 140 | 18th February 2012 10:14 PM |
| speaker protection | audiofan | Solid State | 0 | 19th February 2009 02:35 PM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| Page generated in 0.06564 seconds (74.98% PHP - 25.02% MySQL) with 10 queries |
