Low Distortion Oscilator schematic anybody?
Old 9th September 2003, 03:55 PM   #1
tschrama is offline tschrama  Netherlands
Default Low Distortion Oscilator schematic anybody?
Hi All,
I've done a search on this on the forum and indeed found some, but some values are missing or the link is dead. Maybe someone has got a nice little schematic for <0.01% oscilator, fixed frequency is OK.
Many greetings,
Thijs
Old 9th September 2003, 04:54 PM   #2
Come on guys, there must be plenty around.....
I found this one:
http://www.diyaudio.com/forums/showt...7435#post27435
Allthough the lamp is specified as 5W, I rather would like to now it's current rating ... does anyone know?
could I use a netwpork of 2 or 4 diodes/resistors instead to provide a non-linear resistance? Or would that yield high distortion?
Thijs
Old 9th September 2003, 05:05 PM   #3
hitsware is offline hitsware
http://www.linear.com/prod/datasheet.html?datasheet=148
........here's another
Old 9th September 2003, 05:16 PM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Is 5 ppm (0.0005%) good enough? This wienbridge is rather complicated and needs a good pcb I imagine.
http://www.linear.com/prod/datasheet.html?datasheet=202
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 18 pcb's in interest.
Old 9th September 2003, 05:19 PM   #5
peranders's Avatar
Default Re: Low Distortion Oscilator schematic anybody?
Originally posted by tschrama
Hi All,
Have you considered an ordninary sound card?
My "junk" card gives 0.0087% distortion, Turtle Beach Santa Cruz.
Tone generator (excellent freeware): http://audio.rightmark.org I haven't checked if the software can produce sinus signals but I think so.
Old 9th September 2003, 05:44 PM   #6
jackinnj is offline jackinnj  United States
jackinnj's Avatar
this idea appeared in AudioXpress -- you take a square wave generator (which can be a simple multivibrator type, xtal etc.) and pass the signal through 2 stages of filtering with the Linear Tech LT1063 low pass filters -- the distortion will be well below what you are looking for and the filter is very easy to tune
you just use a variety of counters to select the frequency
it helps if you have a "post filter" to remove the vestigial clocking noise from the circuit.
this won't get you a lot below 0.01%, but in the ballpark and without the need of ganged potentiometers, etc.
I have even experimented with this using the PicBasic Pro FREQOUT function on a 16F84 multiprocessor and gotten good results.
Old 9th September 2003, 06:21 PM   #7
Thanks .. got some reading to do
greetings,
Thijs
Old 9th September 2003, 06:38 PM   #8
PMA is offline PMA  Europe
PMA's Avatar
The Linear Technology circuits really work as they should ...
Old 9th September 2003, 06:53 PM   #9
Hi everybody,
I just read the LT1037 opamp datahseet ...
The oscilator shown uses a #327 lamp ..... hmmmmmm I gues that means 5 Watt
Can anybody give me some clues about what kind of lamp I need .. something like 12V / 200mA or more like 6V / 10mA?
Thijs
Old 9th September 2003, 07:00 PM   #10
PMA's Avatar
I would follow the perander's link to low-distortion oscillator, as thinks start to happen near 0.001%, not 0.01% .. . Also have a look at LT1122 datasheet ..
Low Distortion Oscilator schematic anybody?Hide this!Advertise here!
need schematic for 12au7a distortion overdrive and fuzz prorms Instruments and Amps 4 4th February 2008 06:53 PM
Have anyone a triangle oscilator? Whortless Class D 0 6th June 2006 11:43 AM
CD4001BE Oscilator hayes Digital Source 0 1st May 2004 08:26 PM
not gate oscilator sss Digital Source 6 24th October 2003 09:03 PM
oscilator needed sss Digital Source 5 19th October 2003 03:32 AM
