L20 V8
L20 V8
Old 13th December 2011, 12:32 PM   #11
east electronics is offline east electronics  Greece
east electronics's Avatar
250w at 8r with just 2pairs of transistors.... that cannot be correct
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th December 2011, 12:53 PM   #12
Ian Finch is offline Ian Finch  Australia
Hi Sakis
No, OP says just 2 pairs now for testing - turn the board over and fit another 2 pairs on that side (later).
'Sure makes it a tight board, though
If only I had listened....
Old 13th December 2011, 12:57 PM   #13
thanks Ian ( how are you by the way ? )
still this doesn't look very good 70 volts are just enough for 250W.... and then of course pcb needs to be redesigned to handle the power and accommodate supporting circuits such is zobel with inductor , VI limiters , any other limiter and Dc protection
Old 13th December 2011, 01:09 PM   #14
Pingrs is offline Pingrs  United Kingdom
Originally Posted by astankov View Post
Interesting! Can't see a thermal sensor on the heatsink.
You say temperatures are very low - how did you bias the outputs?
And again can we see a schematic please?
It's CFP - the sensor will be on the driver heatsink, I guess.
Brian.
Old 13th December 2011, 01:14 PM   #15
aaa...marvelous...250 W cfp ..... that will make a perfect oscillator !!!!!
Old 13th December 2011, 02:36 PM   #16
Default CFP output
Ohhh...I thought you liked P3a with CFP, even in bridgemode, Sakis - anyway, I'm well and I hope business is improving for you, this Christmas
My best wishes to your family and I hope your son is growing and learning to solder now... You will make more profit when he gets the hang of it and you can take a break and DIY some more. I think we need to hear another P3a comparison this Christmas...anything in mind?
Old 13th December 2011, 02:41 PM   #17
ljm_ljm is offline ljm_ljm  China
Originally Posted by rickedd46 View Post
ljm_ljm,
How many versions of the L20 are there? I saw a L20, V7, V9 and others on ebay
Which one is better?
And why?
Thanks.
L20 Now to the sale of the VER7 and VER9 version.
VER9 used the MOSFET driver
Old 13th December 2011, 02:46 PM   #18
yes. it is a MOSFET+ BJT OUTPUT CFP.
AND CFP INTPUT..
It is very stable. Reliable.
Old 13th December 2011, 02:52 PM   #19
rickedd46 is offline rickedd46  United States
Thanks for replying.
What are the benefits of mosfet vs. bipolar inputs on this particular board?
Do the output transistors behave more linearly with the mosfets vs. the bipolar inputs?
Or is it a matter of lower distortion?
Sorry for all the questions. I have to make a choice soon.
Old 13th December 2011, 03:01 PM   #20
well Ian ...is still believe that a properly made CFP is the best way to go for class AB Bjt domestic application ....
Repairing an average of 400 amplifiers per year i may tell you that never seen a properly working CFP with more than 2 pairs of BJT outputs especially at this rate of power ...all attempts in the past failed and if any working only made for limited bandwidth to avoid oscillations ....
Just a few days ago i ve seen Italian design of CFP with 2pairs per ch. while each and every one of them had its own driver ( 4 drivers totally )...... nightmare !!! imagine miller caps of hundreds of picofarad in both drivers and outputs to stabilize ...
obviously nice idea but bad approach plus that its almost impossible to repair if you don't have proper transistors plus properly matched ...
The only possible way to stabilize is to use fast drivers and slow outputs but after that the all design is degraded regarding sonic performance ...May good enough and stable for pro use but out of the question for hifi or above applications ...
My 2 cents
L20 V8Hide this!Advertise here!
L20 AMP。use only two NJW0302G ljm_ljm Solid State 98 2nd February 2018 04:31 PM
ebay amp L20 power amplifier meko Solid State 60 15th December 2016 03:51 PM
Has any one tried this l20 - 350 watt amp srinath Chip Amps 1 12th January 2011 06:10 PM
V8 Fonken design ? Bigun Full Range 30 28th January 2009 08:58 PM
Fast tractor - V8 peranders The Lounge 1 15th October 2008 02:47 AM
