BJT, MOSFET or JFET? Which sound better in class-A
Old 6th November 2011, 05:38 PM   #1
neazoi is offline neazoi  Greece
Default BJT, MOSFET or JFET? Which sound better in class-A
This is a very general question which depends on many factors of course but in general which one should sound better in a single ended class-A stage, BJT, MOSFET or JFET?
Great DIY site: http://www.neazoi.com
Old 6th November 2011, 11:10 PM   #2
CBS240 is offline CBS240  United States
CBS240's Avatar
MMMmmmm J-fets..
Unfortunately power J-fets are a thing of the past.
All the trouble I've ever been in started out as fun......
Old 7th November 2011, 12:49 AM   #3
AKSA is offline AKSA  Australia
Try the new SemiSouth power JFETs. Aside from a stiff gate current, they are reputed to be very good by Nelson Pass.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 7th November 2011, 08:09 AM   #4
ingenieus is offline ingenieus  South Africa
I've seen more MOSFETS in single-ended class A amps than BJTs.
Must be because they require less circuitry as far as pre-drivers, temperature compensation e.a. go, therefore they fit in better with the minimalist philosophy of single-ended class A.
Old 7th November 2011, 09:23 AM   #5
That would be the SJEP120R100A and SJEP120R063ASiC JFETs for audio
SiC Transistors | Semisouth Laboratories, Inc.
It would be nice if they published SPICE models...
Old 7th November 2011, 09:42 AM   #6
I can see a tension towards audio morfets of new audio jfets. What about bjt.
constructions like these have remarkable sound from my listening impression.
Le monstre
Old 7th November 2011, 11:33 AM   #7
MosFETs in ClassAB do not seem to respond to optimal bias voltage/current in reducing crossover distortion. This makes ClassAB for BJT & FETs somewhat different.
Most knowledgeable commentators draw attention to the FACT that mosFETs seem to get better the more the output bias is increased. I recall Borbely mentioned 500mA of output bias as minimum recommendation for every mosFET amplifier.
It is only a small leap of faith to move from >=500mA of bias to full ClassA and then there can be no crossover distortion to attenuate.
To me, that seems to explain why mosFETs predominate in small ClassA amplifiers.
regards Andrew T.
Old 7th November 2011, 12:08 PM   #8
Default Mosfet switching transitions in Class AB
Andrew,
You may not need that much. Here is the (simulated) crossover event depicted by the source resistor currents on a mosfet AB output stage. The pmos (R18) is rather more linear than the nmos (R17), but you can see the transition is well controlled with no sign of ringing or instability. This is into 8R//100nF, a difficult load, at 1KHz.
Quiescent current is just over 150mA.
I feel that modern mosfets do not lose out too much to bipolars these days.
Hugh
www.aksaonline.com
Old 7th November 2011, 12:23 PM   #9
Hugh,
I do not think that your example is a good guide to what modern FETs can achieve in terms of reducing crossover distortion and doing so at lower bias currents.
regards Andrew T.
Old 7th November 2011, 12:58 PM   #10
toprepairman is offline toprepairman  United Kingdom
If properly designed they won't sound different at all, not even a tiny bit.
BJT, MOSFET or JFET? Which sound better in class-AHide this!Advertise here!
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 61 2nd October 2015 07:35 AM
Single BJT VS JFET Preamp tmblack Solid State 7 2nd November 2011 07:05 AM
3T HeadPh Amp. JFET-BJT-MOSFET lineup Solid State 39 4th July 2009 08:28 PM
10W JFET/MOSFET SE Class A, no Feed Back widowmaker Solid State 9 26th November 2006 02:00 PM
Help me with my JFET / BJT design RichardJones Solid State 14 14th March 2003 04:19 PM
Copyright ©1999-2017 diyAudio
