Old 5th November 2011, 11:49 PM   #1
pepsi is offline pepsi  United Kingdom
pepsi's Avatar
Question Determining the polarity of the speaker outputs on my amp.
Hello Everyone,
I'm new to this forum but would like to pick your brains about how I can determine which of my amps speaker outputs are positive or negative as it is not labelled. I have made a "wallin impedance jig II" for measuring t/s paramaters with speaker workshop. will the jig and speaker workshop be able to help me with the amp problem? Is an impulse response test the correct test?
I'm trying to get my head around audio measurement.
Your help would be much appreciated.
Many thanks, Matt
Old 6th November 2011, 01:13 AM   #2
jaycee is offline jaycee  United Kingdom
Open it, find the PSU power ground, and continuity test to the speaker terminals. The negative one will be the one that has continuity. Do this with the amp off and make sure the power supply capacitors are discharged!
You could probably also get away with not opening it and using the signal ground from one of the signal inputs, but thats less reliable.
If your amp is a bridged mode amp, forget it.
Old 6th November 2011, 01:21 AM   #3
Francec is offline Francec  Australia
Banned
If the power lead has an earth pin, test for continuity between it and speaker outs.
Old 6th November 2011, 12:48 PM   #4
pepsi's Avatar
Hi Jaycee and Francec,
It's not a bridged amp so I'll try both your methods that don't involve opening it and hope they work before I open it. Many thanks!
Amp with multiple stereo speaker outputs hazymat Solid State 7 26th June 2011 10:47 PM
Speaker wire polarity JoeJoe Parts 5 4th October 2010 11:57 PM
Determining a nominal impedance of a finished speaker rabbitz Multi-Way 4 26th October 2008 02:00 PM
Determining the Polarity of a Great Heil SilverFox Planars & Exotics 7 3rd May 2007 12:41 PM
determining power handling of a speaker GeniX Multi-Way 3 14th October 2002 03:40 AM
Page generated in 0.06831 seconds (78.61% PHP - 21.39% MySQL) with 10 queries
