Vertex Amp By apexaudio
Old 7th November 2011, 02:34 AM   #51
ravpreet420 is offline ravpreet420
Hello apexaudio
firstly thanks for all support
please sir share clip circuit for this amp and dc voltage and capacitor requirement for full power.
thanks
Old 7th November 2011, 06:22 AM   #52
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
PSU for Vertex, signal+clip led and speaker terminal for double protect if relay blow up.
Old 7th November 2011, 02:22 PM   #53
apexaudio's Avatar
This circuit can be use for bridge, use low rail voltage (+/-50V) or 2k2/2W replace with 10k/5W.
Old 9th November 2011, 04:29 AM   #54
tahpoj is offline tahpoj
@ irvynejay
sir irvynejay, where did you buy your ir2117. I'll try to buy in raon but there is no available. Thats why i can's start building the H900 apex amplifier. And now ill try to build your vertex amp by apexaudio, but my problem is, there is no available IR2117 here in manila.
tahpoj
Old 9th November 2011, 09:43 PM   #55
engel dela pena is offline engel dela pena  Philippines
sir jay bom po
Old 9th November 2011, 09:45 PM   #56
apex,
how about using dr. bora's OMNI PROTECTOR for vertex?
Old 11th November 2011, 10:16 AM   #57
irvynejay is offline irvynejay  Philippines
irvynejay's Avatar
Send a message via Yahoo to irvynejay Vertex Amp By apexaudio
Default Protection
Hi Mile Could this circuit be applied on vertex
this maybe short overload circuit protect of c##t amp pls correct me im wrong
Old 11th November 2011, 10:50 AM   #58
apexaudio's Avatar
I suggest to use protect circuit from post #44.
Old 11th November 2011, 10:56 AM   #59
irvynejay's Avatar
Ok thanx mile But where to connect the D15 and prot terminal on vertex?
Old 11th November 2011, 11:03 AM   #60
Default hello apexaudio
plz sir correct this
Vertex Amp By apexaudioHide this!Advertise here!
WTT: OCZ Vertex 2 180gb 3.5 inch john dozier Swap Meet 0 2nd April 2011 01:32 AM
Require the icom 802 HF Radio and standard vertex VHF spare ramay Swap Meet 0 11th July 2010 05:26 AM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
