#41 |
This Limiter circuit with low cut filter can be use with XLR circuit add on input.
http://www.facebook.com/APEXaudio.MileSlakovic |
#42 |
hello sir,
do you have separate pcb pattern for this limitter |
#43 |
Thanx Mile for your support
#44 |
For protect I suggest this circuit with NE555 and 30A 12V relay.
I haven't pcb design for this circuits.
#45 |
R318, R418 can be replaced with 1k pot to set limit level (1,5v).
#46 |
can the balance input and low cut filter be remove and use only the limiter circuit?
#47 |
Yes, low cut filter can be removed, and there is no balanced input on this circuit.
#48 |
Thanx mile ill post when my limiter is done
#49 |
Dear Alex MM
please post your PCB schematic & layout, if you can. |
#50 |
Simple fan control circuit.
| WTT: OCZ Vertex 2 180gb 3.5 inch | john dozier | Swap Meet | 0 | 2nd April 2011 01:32 AM |
| Require the icom 802 HF Radio and standard vertex VHF spare | ramay | Swap Meet | 0 | 11th July 2010 05:26 AM |
| Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 | quality sound | Tubes / Valves | 0 | 9th May 2009 03:59 PM |
| DIY-AMP <ZAS> Low THD & IM high bandwith | murphy | Solid State | 18 | 30th December 2005 10:28 AM |
