Vertex Amp By apexaudio
Old 10th June 2013, 12:04 PM   #151
Stevey is offline Stevey  United Kingdom
Hi Apex audio. Can I change amp this to a 2 step version with 150v and 75v rails ? I have just got a 3.5kva transformer with 53v windings x 4. Can I just leave out the lower voltage stepper ? and do you think this will affect the efficiency much.
Thanks for all the work your have shared.
Old 17th June 2013, 03:41 AM   #152
SERGIODS is offline SERGIODS  Peru
Default hello
Originally Posted by alex mm View Post
...... Hmmm very close to my PCB or vice versa
Hi Alex. Good information, where I can download files in Sprint layout.
Old 16th August 2013, 09:28 PM   #153
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Can anyone share the schematic of this amp please....
Thanks...
Old 17th August 2013, 06:13 AM   #154
ChingTan is offline ChingTan  Philippines
ChingTan's Avatar
Send a message via Yahoo to ChingTan
i think same with apex vertex but without 3rd step
Old 17th August 2013, 07:21 AM   #155
wiljj78's Avatar
Yes this is APEX vertex amp, i try to redraw this amp but i have little doubt on the drawing, if you have the schematic please share.
Old 17th August 2013, 05:33 PM   #156
khalsa is offline khalsa  India
Send a message via Yahoo to khalsa
very nice sir i like your every drawing
Old 17th August 2013, 05:36 PM   #157
mj777 is offline mj777  Australia
Default vertex schem
I hope this helps, schem. from apex before.
regards,
mj777
Old 17th August 2013, 05:49 PM   #158
wiljj78's Avatar
Thanks...
This is half way to go....
Old 17th August 2013, 06:27 PM   #159
Hi wiljj78, is it possible for the 4 driver transistors(mje15034/35) in the middle to be fix in the main heatsink under the board?
regards,
mj777
Old 17th August 2013, 06:43 PM   #160
wiljj78's Avatar
No problem will try that option too...
Vertex Amp By apexaudioHide this!Advertise here!
WTT: OCZ Vertex 2 180gb 3.5 inch john dozier Swap Meet 0 2nd April 2011 01:32 AM
Require the icom 802 HF Radio and standard vertex VHF spare ramay Swap Meet 0 11th July 2010 05:26 AM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
