Old 3rd November 2011, 05:25 AM   #1
Default Metal Film vs. Bulk Foil resistors
Right now I have a voltage divider for each channel in my amp bypassing gain pots--fixed voltage divider of (0, 20k ohm). I am using a Metal Film 1% tolerance resistor right now for each channel--each measuring exactly 20.0k ohms on my multimeter.
Would I hear an audible improvement if I replaced those 25 cent metal film resistors with 20k ohm Vishay bulk foil resisters? They cost $20 for each resistor--so it would be a $40 "upgrade".
Old 3rd November 2011, 01:48 PM   #2
Audible improvement will depend on how good your system (electronics & speakers) is in fine resolution.
There are also different types in Vishay BFs, and prices. Have a look at Percy's, that stocks them all and has good prices:
Michael Percy Audio Ordering Information
Old 3rd November 2011, 04:12 PM   #3
I very much doubt it. Metal films have good linearity and excess noise properties already. I think the only types of resistors with problematic linearity are carbon composition and thick film.
EDIT: Reading up, it seems carbon films aren't exactly the very definition of linearity either (though less bad than carbon comps), but I think they were used in lots of audio equipment in the past and few people ever complained. The voltage coefficient of metal films is only about 1% as high as with these.
Old 3rd November 2011, 05:42 PM   #4
Spend your money on Linear Audio Vol. 1 where different resistors results are shown. With the change leftover you can buy some good resistors and a small bottle of wine.
Old 3rd November 2011, 05:52 PM   #5
I've noticed more of an improvement by going to .1% from 1% then changing to bulk foil.
Susumu .1% 1206 SMT RG series from Digikey; 64 cents each.
Not a huge amount of money for a decent component.
Old 15th November 2011, 08:37 PM   #6
Mike, can I use the surface mount resisters like I do the 1% metal film resisters, and not on a printed circuit board?
Old 15th November 2011, 09:10 PM   #7
Bone is online now Bone  United Kingdom
The audible improvement will be in direct proportion to how much you pay for them.
Old 15th November 2011, 09:29 PM   #8
NO, you are wrong, Bone. The best resistors will measure the 'best' as well for the most part. For example, $10 Vishay bulk metal does not sound better (to my ears and many others) as a Roderstein Resista ($0.10). The measurements show similar performance. So 100:1 difference in price is not that different. Trust me, I use both for serious designs.
VISHAY VTA 55 Bulk Metal Foil Resistors? phrarod Tubes / Valves 3 11th August 2011 07:42 PM
Vishay bulk metal foil resistors 2kohms RNC90y elviukai Swap Meet 1 3rd February 2011 02:11 PM
FS Vishay bulk metal foil S102K merlin el mago Swap Meet 12 3rd December 2010 10:42 AM
Vishay bulk foil resistors - where to buy? sublemon Parts 2 22nd October 2005 05:15 AM
Black gate caps and vishay bulk foil resistors biovizier Parts 1 21st June 2005 04:20 PM
Page generated in 0.08929 seconds (75.13% PHP - 24.87% MySQL) with 10 queries
