Hi to everyone. Is my first post.
I have the next problem with the Lehmann BLC ("Lovely Cube") With the gain at 0db. I have not amplification. I have to put the volume to maximum to hear the same volume as I listen to my Sansa Clip + directly without amplificator. Even a little less with "lovely". With the gain to 10, 18 and 20dB I have changes in the output sound. I have SOME LITTLE amplification but I have yet to set the volume to maximum to have enough volume to hear worthily. I have to say that I don't have hearing problems. My Lovely does not amplify the input signal !!! Attached photos of my PCB front and bottom. https://www.dropbox.com/gallery/2747...ovely?h=53f1a2 * Will note that I've made changes of components for originals equivalents. All changes with same capacity in the case of capacitors and the same resistance in the case of resistors ( I've only changed the value of the four 1K2 resistances by 1K5). * I changed the LM317 and LM337 by originals 337T and 317T with bigger heatsinks. * I changed BD139 and BD140 by BD139-16S and BD140-16S. * I changed BC550 and BC560 by BC550CG and BC560CG. * Input bigger capacitors have different format but are same capacity and voltage that stock lovely clone. Smaller input capacitors are MKP 22nF/1000V. (i had tested with originals and i had the same problem). * 22nF opamp capacitors are KP1837. * 100pF opamp capacitors are LCR FSC (100pF/160V./2,5%) * Opamp is original 2134 . With 2134 and 2111AM lovely stock i have the same problem. I have reviewed all solders. I have tested dip switches for gain function properly off and on. All components are in place. I have measured voltages with digital multimeter: - BD140 BD139: collector-base .- 14v. collector-emitter .- 14v. base-emitter .- 0.6v. - BC550C BC560C: collector-base .- 15v. base-emitter .- 0.6v. - LM317T LM337T : Adj .- 13.8 v. Input .- 21.6 v. Output .- 15.0 v. (-15.0 for LM337T) - OPAMP 2134 is receiving 14.7 v. I have replaced the opamp with the stock. I have changed the sound source by putting my phone with the maximum volume. Despite all this I still have to put the volume to maximum to hear the music. Even on 20db. gain !!. With 0dB. even I noticed that the sound is attenuated. HELP !! I'm pretty worried. I do not understand what is happening. Any suggestions.??? |
#2 |
Check your R15/16, R17/18 and R21/22 (L/R channels) for the correct values. These resistors set the gain of the op amps.
#3 |
Thanks Odysseybmx414, all this resistors are OK. (4,7K).
I have checked all resistors in its places and values. Last edited by Miky2011; 31st October 2011 at 11:11 PM. |
| Crossfire "Distinct Audio" TD-1002 problems | Dr Zeus | Car Audio | 53 | 29th November 2010 01:49 PM |
| FS: Lehmann Audio Black Cube MM/MC Phonostage | enjoythemusic1 | Swap Meet | 0 | 27th August 2010 04:27 PM |
| Problems with "shallow" cabinet design? | mfellman | Construction Tips | 2 | 12th April 2010 04:38 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Lehmann Black Cube Phono Stage | mg16 | Swap Meet | 1 | 14th April 2008 04:22 PM |
| Page generated in 0.08268 seconds (75.97% PHP - 24.03% MySQL) with 10 queries |
