Hi - I am replacing the faulty speaker relay in my Rega Elex MkII (see pics). I have a couple of questions hopefully someone can help me with.
To unsolder the relay I had to lift up the PCB which is held to the casing by two allen key screws through the black u-shaped bar which also clamps the output transistors onto mounts in the casing. Under the PCB is a layer of insulation with holes for the output transistor mounts. It seems there is some (brown) thermal insulating tape between the transistors and the mounts. Should I replace this Also, there are a couple of blobs of some glue-like but not very sticky substance that seems to stop the front panel insert and the PCB rattling around. What could I use to replace that with? Indeed, what is it exactly Have to say I'm not very impressed with the quality of construction, but then I guess all the quality went into the price, not the product
NAD: C730, C541i; 7100, 5000; Rega (clamshell): Mira, Planet, Radio; Denon: DR-M14HX |
#2 |
The thermal pads should be OK if they're still soft and look undamaged, but after assembly check that the transistors aren't shorted to the chassis. Personally, I would put a tiny smear of thermal paste on these pads as insurance if they can't be replaced. The glue blob is fairly standard assembly practice these days. If it doesn't get hot there then hot glue would be OK to use and is my preference because it's easy to get off if needed. If it does get hot then a blob of RTV would do but is harder to get off cleanly.
#3 |
Thanks for the tips, but I'm not sure what you mean by RTV. Is this the stuff?
Silicone 401 RTV |
#4 | |
This is the proper stuff by the way..... http://www.alibaba.com/product-gs/48...retardant.html Last edited by sbrads; 29th October 2011 at 09:41 AM. |
#5 |
Hi mashley.
The glue like substance is most definatley of the hot melt varity. also notice in the same piccy as the glue, two transistors marked T1 they seem to have thermal jointing paste on them does somthing make physical contact with them when the unit is assembled? It may just be to bond the two smal ltransistors thermally rather than for cooling . Just a word of caution using silicone substances, Speaking from expirience this stuff can be conductive at audio frequencys. Regards Ian |
#6 |
It must depend on the type of RTV then as we use it at work where it passes 100MΩ insulation requirements at 1Kv DC (and AC when required) and usually measures over 1GΩ.
#7 | |
regards ian |
#8 |
Well spotted, but no that's just some colour coding; most of the little transistors have some blob of colour on them.
#9 |
The relay was successfully replaced with an exact replacement Finder model 50.52.7.024.0000 (24 V DC, DPDT, 5A).
The two glue globs did not need to be replaced afterall, as I found they effectively just "clipped" back into position. The heatsink insulator strips were also in good shape, so other than giving the output transistors a wipe clean, I made no changes here. The thing with these Rega amps is that a lot of heat comes off the driver transistors (which I think must operate in class A) and it is these which heat the cabinet rather than the output transistors themselves. Lack of proper ventilation to cool the interior is a design flaw, but despite this, the amps seem to work well and don't seem to overheat despite running very warm. All back together and working well!
| Need the Rega Brio-3 amp schematic | gaetan8888 | Solid State | 1 | 24th November 2011 06:25 PM |
| Repairing a Rega Elex Integrated Amplifier | TATER1971 | Solid State | 4 | 29th September 2011 12:58 AM |
| Rega Mira 3 schematic | Polesov | Solid State | 17 | 25th July 2007 06:39 PM |
| HELP with a rega brio! | jercab | Solid State | 1 | 5th October 2005 01:43 AM |
| Rega Brio (one channel dead) | cosinus | Solid State | 19 | 14th August 2005 04:41 PM |
| Page generated in 0.11773 seconds (77.93% PHP - 22.07% MySQL) with 11 queries |
