I have an pro-amp that has an unbalanced line input that consists of a 10ohm drain resistor and a 220uF blocking electro just before the op amp. These values seem odd to me (cap too high, resistor too low) and I get a corner freq of about 72Hz which seems awfully high. I'm thinking of changing the resistor to 10k and the cap to a 2.2uF tantalum. Is that desirable?
#2 |
Schematic?
Frank |
#3 |
Right. First off, apologies for posting and running but life, unlike amplifiers, is rarely linear
Screen Shot 2011-10-27 at 12.48.49 PM.png 5C8 10nF ceramic R108 100K 5C22 220uF R89 220ohm R88 100K 5C25 10nF ceramic |
#4 |
If you're measuring DC resistance, C-5C8 should read as an open circuit, and C-5C22 should read initially as a low value resistor that rises in value until it is fully charged to the meter's probe voltage and then read as an open circuit also, so after C-5C22 fully charges you should be seeing only the resistance of R108. So if DC resistance reading isn't somewhere around 100K, you have some bad caps in there. Also, I don't recommend using tantalum caps anywhere in audio circuits, not even for power supply decoupling due to there extremely high distortion characteristics, use a good quality film cap instead.
Mike |
#5 |
Thanks. I suggested tants because that is what I have on hand and didn't want to spend more money on this. I have some Sprague 3.3uF axial films that I can make fit but the board is fairly tightly packed so I doubt radial films will work. I'll just add that when I measured, 5C22 was already removed so only 5C8 was present. Now that its gone (it will be replaced for safety sake), the resistor measures fine.
#6 |
R108 discharges current leakage through the DC blocking cap.
6C8 adds in a bit of VHF attenuation.
regards Andrew T. |
| mp3 input to reciever poor sound quality | sadams | Digital Source | 2 | 23rd April 2011 09:09 PM |
| spdif input circuit help | burbeck | Digital Source | 31 | 15th September 2005 03:28 PM |
| New SPDIF input circuit. | gmarsh | Digital Source | 11 | 7th April 2005 03:05 PM |
| HELP! Differential Input Circuit | mtnickel | Solid State | 33 | 26th September 2004 09:13 PM |
| Page generated in 0.08949 seconds (76.17% PHP - 23.83% MySQL) with 11 queries |
