Old 26th October 2011, 08:17 PM   #1
Default Does a metal/conductive enclosure need to be grounded in order to shield?
If safety earth is not brought in at all, ground loops cease to exist - but does the enclosure still act to shield from electric and EM interference?
How is this different from a cable with shielding disconnected at both ends?
Old 26th October 2011, 08:24 PM   #2
Ground is generally applied to all return voltages that are referenced to zero volts.
The Safety Earth is referenced to PE.
If PE does not exist, that still leaves all the other grounds and ground loops among those conductors most certainly can exist.
regards Andrew T.
Old 26th October 2011, 08:31 PM   #3
NicMac is offline NicMac  Italy
NicMac's Avatar
I would say that a shield needs a drain to work, although common sense tells me a metal box thick enough will keep EMI out without grounding....
I have always been taught to keep cable shields connected at one end....
In any case it is perfectly possible to ground the chassis without creating any loops loops.
Nic
Old 26th October 2011, 08:36 PM   #4
What I'm thinking of is an aluminum box, with insulated connections, with power delivery via two-conductor wall-wart. The box should not be part of any circuit...?
Old 26th October 2011, 08:54 PM   #5
auplater's Avatar
Faraday cage - Wikipedia, the free encyclopedia
"...His brain is squirming like a toad..." Jim Morrison
Old 26th October 2011, 08:55 PM   #6
jcx is offline jcx  United States
Default its not a Faraday Cage with holes, wires to the outside potential
the box will be a capacitive antenna to the outside world, and capacitively couple to your circuit
how effective it is for magnetic fields depends on material, thickness, frequency
at high enough frequencies you will get reflection, absorbtion of incident EM waves
but because of the capacitive coupling of lower frequency E fields the enclosure, or an inner circuit shield should be grounded to signal ground
some interpret electrical safety codes to require PE for any exposed metal
double insulated, "reinforced" insulation with 4 kV Hipot pri-sec mains transformer meeting creepage, clearance requirements, internal mains wiring insulation, construction standards should be safe without PE
this requires securing all mains side wiring, adding supplemental insulation such that any single failure will still meet insulation, spacing requirements
Old 26th October 2011, 08:58 PM   #7
NicMac's Avatar
Old 26th October 2011, 09:10 PM   #8
Speaking only to the last point, does all low-level voltage need to be Class 2 insulated if PE is not present? I mean we're talking less than 3V signal and a Class 2 wall wart, here.
Old 26th October 2011, 09:11 PM   #9
auplater's Avatar
Default What'snot a Faraday Cage?
a bit presumptive about a seemingly open ended question, eh???
Without more information as to application, it most certainly could be a Faraday cage
Old 26th October 2011, 09:15 PM   #10
I guess this is a little academic anyway. It is not a problem for me to short the enclosure to another enclosure which is connected to PE via safety earth.
Should tripath pcb be grounded to metal case ground? artfuldodger Chip Amps 2 23rd September 2011 02:23 PM
Enclosure Shield for noise reduction trv Construction Tips 4 29th May 2010 09:10 AM
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 02:10 PM
Metal strength for enclosure rtarbell Parts 5 6th September 2008 07:39 PM
metal shield dud_wity Tubes / Valves 3 11th July 2004 10:30 AM
Page generated in 0.12819 seconds (75.49% PHP - 24.51% MySQL) with 10 queries
