Old 26th October 2011, 07:05 PM   #1
Default Amp efficiency
I need help understanding how amplifier efficiency affects power draw vs power output.
Let's say I require 40 Vp-p, sine wave, going into a 4 ohm resistive load; e.g. 7 amps. If the amplifier is 80% efficient, what is the required rail voltage and DC current draw?
Old 26th October 2011, 07:44 PM   #2
Did it Himself
richie00boy's Avatar
As the amp is 80pc efficient its rail voltage must be (100/80) x (40/2) = 25V.
DC current draw will always be 7A as current cannot disappear or appear along a route with only series elements.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th October 2011, 07:59 PM   #3
Excellent, thanks.
Old 26th October 2011, 08:19 PM   #4
7Apk into 4r0 requires 28Vpk, that is approximately 20Vac.
28Vpk is the same as 56Vpp not 40Vpp
regards Andrew T.
Old 26th October 2011, 08:22 PM   #5
Oops, you are correct. I accidentally doubled. I guess 40Vp-p is 3.54Arms through 4 ohms?
Old 27th October 2011, 12:23 AM   #6
I am afraid you are in error. Verry few amps will have a output swing rail to rail usualy
for a 40vpp output you will need about rail voltages of about 25 + and - . Well 20 v across 4 ohms will be 5A but when 5A is being drawn from the + supply on a voltage
peak no power is being drawn from the - supply rail. And you specified a sine wave so
your current through the output device will swing from 0A to 5A on the + part of thewave and 0 to 5A on the negative part of the cycle. But you asked for the DC curent draw well I don't think you will have any DC curent draw ( well maby 50ma or so bias ) My math isn't worth a hoot but you would probably be safe to figure a little
less than 2A average current per supply rail.
Old 27th October 2011, 11:18 AM   #7
djoffe is offline djoffe  United States
This 3 page white paper may be useful...
http://updatemydynaco.com/documents/...lculations.pdf
Suppo el84 amp ($70), high-efficiency mid (Audax 17prmo - $100)) Ang Swap Meet 5 3rd June 2010 03:50 AM
High efficiency 5 1/4" sub for T-Class amp roadsterdriver Class D 4 6th September 2009 01:46 PM
High Efficiency Mini DIY Speakers for T-amp DreadPirate Multi-Way 7 6th February 2009 01:48 AM
Keele, D. (2004) "Maximum efficiency of compression drivers" svenr Multi-Way 3 28th October 2007 02:03 PM
Best PASS amp for a high efficiency full-range speaker? HeadSh0T Pass Labs 37 24th December 2004 04:50 PM
Page generated in 0.09317 seconds (68.87% PHP - 31.13% MySQL) with 10 queries
