Lets have a party
#2 |
One could use a buffer of their choice. However an opamp based buffer will also work out. Here attached is an opamp based buffer. Opamp choice is flexible. The fourier analysis is for +-1.2v output.
#3 |
I am intrigued, explain what made you do this.
Kind regards Nico |
#4 |
Well Nico, its a long story but this might help
Faster than light particles found, claim scientists | Science | The Guardian |
#5 |
Here is the integrated amplifier. THD is 0.02% 1Watt, 1Khz,4Ohm, the Fourier is attached. THD is at 0.07%, 295Watts, 1Khz, 2Ohm.
#6 |
#7 |
Hi Boyet,
It will indeed work as designed. What I have come up with is a formula for creating great sounding amplifiers (It will hopefully be published soon). I have used this formula against the best reviewed amplifiers and all checks out so far. What I need now are the ears of diyers like you to tell me whether I am right or wrong |
#8 | |
Thank you OnAudio for your reply..I have checked in our local store the availability of MJ11032 and I found it.. I'll wait for the final implementation. Regards, Boyet |
#9 | |
dado |
#10 |
Someone needs to learn about BJT SOA... (295W into 2 ohms from a single pair of darlingtons with atrocious SOA... hm, hm.)
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
| Page generated in 0.12909 seconds (66.33% PHP - 33.67% MySQL) with 11 queries |
