Old 24th October 2011, 09:36 PM   #1
eboz is offline eboz  United States
Send a message via Yahoo to eboz
Default Limitation on floating PS/circuit
What are the limiting factors for floating a particular power supply or circuit above its return potential? Is it just the transformer and wire insulation ratings? I imagine that device ratings should not be a problem, since the difference in potentials all remain the same when floated?
Old 25th October 2011, 01:42 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
I've never floated a supply - but the only factor I can think of that you didn't already mention is capacitance - the floating secondary of the power supply transformer will have some parasitic capacitance to the primary. Most likely it's too small to be of any consequence for audio.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 25th October 2011, 01:52 AM   #3
The one and only
Nelson Pass's Avatar
AC power transformers routinely withstand over 2000 volts to pass Hipot
tests. You can get isolated secondaries or electrostatic shields if you
want them.
Old 25th October 2011, 03:01 AM   #4
jcx is offline jcx  United States
electrostatic shields increase C to each winding they're in between so the load effect would actually be worse
the easy way to minimumize pri-sec C is using split bobbin EI power transformers
a standard construction is "universal/international" double/reinforced insulated - for domestic line V these have to pass a 4KV HiPot test
they are actually better than many "traditional" tube power supply transformers on capacitance, insulation V rating
for even more fun you could float a single polarity supply with anti-phase driven H-bridge output
PS Audio PS Elite Integrate Amp jimmy50 Solid State 14 5th May 2012 06:07 PM
Lost my reply to a time limitation?? roddyama Forum Problems 15 18th August 2010 05:57 AM
Multiple bridge PS, floating gnd question Chamberman Solid State 7 19th January 2007 07:03 PM
(+)(G)(-) rails from a floating (+)(-) PS? 2004ex Solid State 4 21st June 2004 05:14 AM
Floating voltages eeka chu Parts 2 27th January 2004 09:10 AM
Page generated in 0.08190 seconds (71.57% PHP - 28.43% MySQL) with 10 queries
