Old 23rd October 2011, 10:35 AM   #1
paul.42 is offline paul.42  United Kingdom
Default what tx needed
hi all,how do you work out what tx is needed if it is +/- 50v after retifacation.
Old 23rd October 2011, 10:44 AM   #2
35Vac gives ~ 50Vdc, 35+35Vac gives ~ +-50Vdc.
Check through a few posts. You will find many estimating methods and a few that get much closer to reality. All involve the use of SQRT(2).
You need to know the rated input voltage as well as the rated output voltage of your proposed transformer. You also need the VA or current rating and the regulation figure of the transformer.
Finally you need the "normal" voltage available at your home. This "normal" varies from minute to minute and hour to hour, but should always be between the tolerance limits specified by your electricity supplier. Except when there is a mains failure where zero volts becomes available or "brown outs" when the available voltage falls below the lower tolerance limit.
As listeners we would not design for continued maximum sound quality during "brown outs". But we would design for "no damage" in event of mains failure and repeated attempts at restarts.
regards Andrew T.
Old 23rd October 2011, 02:43 PM   #3
Attached a handy chart. E
Old 24th October 2011, 08:29 AM   #4
thanks guys.
James O/P Tx M Gregg Tubes / Valves 11 27th April 2011 07:09 PM
5U4 Darling power TX advice needed waam68 Tubes / Valves 2 14th December 2008 07:15 PM
B+ TX. overkill? Richard Ellis Tubes / Valves 2 26th September 2006 09:12 AM
Onkyo TX-SV919THX Schematic Needed moe29 Parts 0 22nd April 2006 07:00 PM
TX help for GC yuval Chip Amps 11 7th April 2004 08:41 PM
Page generated in 0.07076 seconds (72.38% PHP - 27.62% MySQL) with 11 queries
