I would like to use .01uf 400v capacitor before the bridge rectifier (secondaries) to filter some noise like a snubber. Will this be a good benefit to the bridge?. last time I use 4 of these caps but I put them attached in chain with bridge.sorry I can not find pictures for example, but if you see the schematic of Hafler HD220 you will see cap#405
#2 |
Is C405 10,000 uF in the Hafler? I always get confused by 0.01 mF ... is that millifarads or microfarads?
#3 |
Caps #403 and #404 are 10.000uf 75v. the one I am talking about is the #405 that is .01uf 1000v.
#4 | |
microFarads (µF) nanoFarads (nF) picoFarads (pF) 0.000001µF = 0.001nF = 1pF 0.00001µF = 0.01nF = 10pF 0.0001µF = 0.1nF = 100pF 0.001µF = 1nF = 1000pF 0.01µF = 10nF = 10,000pF 0.1µF = 100nF = 100,000pF 1µF = 1000nF = 1,000,000pF 10µF = 10,000nF = 10,000,000pF 100µF= 100,000nF = 100,000,000pF 1 millifarad is 1000uf Last edited by lanchile; 23rd October 2011 at 06:05 AM. |
#5 | |
In any case, 0.01 mF is not 0.01 uF Last edited by rsdio; 23rd October 2011 at 07:55 AM. |
#6 | |
He was specifically referring to directly across the mains supply, but the argument could equally apply to the secondary side. From what I can remember, he was suggesting 10uF plastic film metal cap across the 110/220Vac lines to present a low impedance to the HF on the mains. Trap it at source would be my equivalent phrase and would locate the 10uF at the distribution board where power enters the house. Adding some uF to the secondary will do similar and since there is resistance and inductance between the first mains cap and this secondary cap it should work well as a secondary HF filter. I sometimes add another cap across the +- of the rectifier. This pair of caps form a cross in the middle of the bridge rectifier. one from ~ to ~ and one from + to -.
regards Andrew T. |
#7 | |
Far better to use an LC filter for such things. I would also locate such a filter inside the equipment as power-line noise is also created on the local house wiring by domestic appliances. Frank |
#8 |
We as domestic consumers do not get charged extra for having a lagging power demand.
Commercial and industrial consumers do pay extra. To avoid the extra cost, they install capacitor banks or similar technologies to reduce the lag of their power demand. If you add a capacitor across your supply, you are adding to the lag reducing effect on the whole grid system. The electricity supply companies will love you for helping to reduce the I^2R transmission and generating losses that increase considerably with a lagging demand. The capacitive reactance does not increase the rate at which your meter reads your consumption. Please inform if any part of my comment is not correct.
regards Andrew T. Last edited by AndrewT; 23rd October 2011 at 10:54 AM. |
#9 | |
#10 |
Look up part1 of Curl's preamp thread.
"Search" in this thread might help finding the references.
regards Andrew T. |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.17448 seconds (71.19% PHP - 28.81% MySQL) with 10 queries |
