Doing some simulation with a complementary JFET input stage using 2SK246/2SJ103, instead of the usually recommended 2SK170/2SJ74 JFETs.
Mostly for fun and to see what I could get out of it. Was a little amazed at the insane slewrate I could achieve and still maintain a nice looking 20 KHz squarewave and good phase and gain margins. Only downside is THD-20 that is around 0.02% at 60 Watt, 8 Ohm load, the 1 W 8 Ohm load THD-20 is a more decent 0.001XXX%. THD-1 1 W, 8 Ohm load is 0.0002XXX% rising to 0.0017XX% at 60 W, 8 Ohm load. Last edited by Neutrality; 22nd October 2011 at 07:47 PM. |
#2 |
20 KHz squarewave, phase and gain margin plot.
#3 |
yes it is literally unbelievable
try setting the sim max step size time in your sim to something appropriate to such an edge - like 1 nS also look at driver bias, output shoot thru - I don't think that 120 Ohm resistor can drain the output Mosfet gate charge that fast |
#4 |
The question here is does your simulation in this case represent the real world? 5pf Cdom seems a bit low to me.
#5 |
I find the 20K waveshape incoherent with that kind of performance: it is much too rounded.
#6 |
To measure the slew rate of an amplifier you measure the rise and fall times of a pulse waveform. Rise time is measured from 10% above the minimum voltage to 90% of the maximum voltage and fall time is measured from 10% below the maximum voltage to 90% of the minimum voltage. If you are measuring a square wave output of an amplifier the 10 and 90% points should be of equal voltage and opposite polarity
The rising slew rate that you measured in your first post (pic #2) was between -31.33 and 20.3 Volts and the falling slew rate (pic #3) were between 33.97 and -16.11 Volts. It’s easy to get insane slew rates when you throw out the slower parts of the signal. |
#7 | |
#8 |
![]() Top: Output, 20V/Div, Bottom: In, 1V/Div F: 20KHz Square performance of my latest design which has about 100V/uS slew.
Negative Feedback: The Need for Speed |
#9 |
100uV/s is a good slew rate.
(sorry jcx ;-) |
#10 |
Ah well, it looked too good to be true anyway.
By using the 10%/90% method for determining slewrate I get a number of around 70V/uS. That was obtained by measuring slewrate between +34V/-34V. Maximum voltage being +38V/-38V. Which sound a lot more ressonable and plausible. |
| Roland/Edirol UA-25 | elingeniero | Digital Line Level | 0 | 20th June 2010 01:54 AM |
| Edirol ua 25ex upgrade | TIQA | PC Based | 0 | 24th February 2010 02:37 PM |
| Edirol UA 25 query | mjkempton | Digital Line Level | 0 | 21st September 2008 08:35 AM |
| LM1875 slewrate | f.sessink | Chip Amps | 1 | 30th October 2007 08:34 PM |
| Edirol UA-1D - opinions | george a | Digital Source | 0 | 29th October 2005 11:40 PM |
| Page generated in 0.09619 seconds (79.72% PHP - 20.28% MySQL) with 11 queries |
