Old 21st October 2011, 11:10 AM   #1
Question is Technics SU-V50 worth repairing...
... or should I use its parts for example Krill
I bought it failured, but visual mint
for now R436, 438 and T411 are burned,
I do not know if other parts are OK
Does anybody hear this amp and recommend its sound?
Please indicate what might be the purpose of burned parts?
regards, Pawel
Old 21st October 2011, 11:13 AM   #2
here goes the schematic
regards, Pawel
Old 21st October 2011, 12:42 PM   #3
sorry for inconvenience
R439 and Q415 are burned, this time R435 survived...
regards, Pawel
Old 21st October 2011, 01:54 PM   #4
jez is offline jez  United Kingdom
It's probably not worth repairing. The module with "class AA" written on it would cost much more than the amplifier is worth. That's if it's even available.
I could be wrong on this but I was given a Technics amp for spares about 12 years ago and I thought about repairing it.... then I got a quote of about £72 for the module!! It was only a low model in the range as well, about 30WPC.
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Old 21st October 2011, 01:57 PM   #5
It certainly looks like it is worth saving.
But then again, if that great big module is gone...
Old 21st October 2011, 03:35 PM   #6
anyway thanks
regards, Pawel
Old 21st October 2011, 03:37 PM   #7
it would be hard to mount discrete transistors to the radiator
which is set for the power module...
regards, Pawel
Old 24th October 2011, 11:05 AM   #8
Hi
(if anyone interested...?)
I found that AN7062 is broken
I ordered new one
and will inform if works after soldering.
regards, Pawel
Old 25th October 2011, 12:11 PM   #9
AN7062 bought and soldered!
Changed burned resistors and transistors...
regards, Pawel
Old 25th October 2011, 12:19 PM   #10
R436 burned with fireworks!
I am starting to thinking what amplifier to build inside V50...
The important thing is a power transformer, has lower and higher voltage taps - the preamp/voltage section might be powered with higher voltage, power section with lower...
regards, Pawel
Technics SU-V50 schematics wanted ZuMbAiU Solid State 11 26th August 2010 11:55 PM
Technics SU-A900Mk2 OXAUDIO Chip Amps 4 2nd July 2008 08:26 PM
Technics SU-V2X zega55 Chip Amps 5 5th January 2008 01:54 AM
Technics SU V85A yeti Solid State 0 28th January 2004 03:21 PM
Technics SU-V900 ? kristijan-k Everything Else 0 26th September 2002 09:00 PM
Page generated in 0.12680 seconds (75.98% PHP - 24.02% MySQL) with 11 queries
